1968 Olds Engine Paint Process
Old Aug 2, 2025 | 09:10 AM
larryfarrell206@gmail.com's Avatar
I'm currently restoring a 68 442 convertible and need a little help with the engine painting process. In 68 was the 400 G motor painted as an assembled long block (intake, valve covers, oil pan and timing cover)? Trying to figure out if the black oxide fasteners where painted.
Old Aug 2, 2025 | 05:11 PM
442Harv's Avatar
All bolts painted engine color.
Old Aug 2, 2025 | 05:33 PM
Charlie Jones's Avatar
Phantom Phixer
The engines were completely assembled, except for the installation of the distributor, coil, carburetor, fuel pump, alternator, starter, power steering pump, and A/C compressor.
Then the engine was electrostatically painted on it's way out the door of the engine plant.
The " accessories " mentioned above were added at the car assembly plant just before the engine was dropped in the chassis.
If you follow this procedure, all the bolts should come out the right color.
Old Aug 2, 2025 | 06:08 PM
Hairy Olds's Avatar
Shoveling Snow
My 67 442 had paint on the starter and the dist.
The by pass hose was painted a little bit also.
The oil filter was also painted and the bottom of the oil pan would be lightly dusted with paint.
Old Aug 3, 2025 | 06:00 AM
Thanks all
Old Aug 3, 2025 | 08:05 AM
Andy's Avatar
Any pics of your to convertible?
mclark68442
Oct 6, 2022 09:41 AM
mattking
Paint
Dec 9, 2021 03:05 PM
Stan Shinker
Jan 29, 2020 01:21 PM
kansjfr
Aug 18, 2015 06:25 PM
Tangovino
Nov 18, 2008 05:30 PM
