Bronze engine paint
Old Oct 1, 2022 | 06:33 PM
mclark68442's Avatar
Bronze engine paint
Anyone have experience using brush-on bronze engine paint on 400 engine? I hate to have the engine pulled for just re-painting. I'm thinking I could pull the rocker covers off and rattle can spray those, I'd like to re-paint the intake manifold and visible areas of the heads & block with brush paint. I've found one vendor that offers Olds 400 bronze brush able paint, just don't know how well it would match the spray in color or looks.... Any experiences?
Thanks.
Old Oct 1, 2022 | 06:52 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
I have successfully rattle caned the engine in the car. 68 442 with AC. You have some tricky meticulous masking to do but it's doable.
My engine wasn't greasy or rusty. I hit it with brake cleaner and carefully cleaned it. The rocker covers should be pulled & prepped for a nice even job. The intake can be cleaned if it's not too bad. Otherwise, it needs to come out and be glass beaded. If you gotta do that MAW install the crossover plugs to prevent the intake from burning off.
I have zero experience with brushing on engine paint. Might be OK for roughcast components, not my first choice though.
Careful...this job reaks of MAWs.
Old Oct 2, 2022 | 09:28 AM
Sugar Bear's Avatar
"Careful...this job wreaks of MAW's"...
that is F U N N Y...
'cause it is so true!
Old Oct 2, 2022 | 11:30 AM
MAW's ???? Someone clue me in.
Old Oct 2, 2022 | 12:08 PM
don71's Avatar
same but different
Might As Well. Its an infectious affliction that says you are only 6 bolts away from anything. Causes projects to sky rocket in time and money.
You are already there, "might as well rebuild the carb".
Old Oct 2, 2022 | 12:11 PM
Bfg's Avatar
Bfg
Might As Well, I once went to change the air filter on my car and wound up rebuilding the engine which led to taking the car off the frame to do a complete restoration. Job completed 10 years later!
Old Oct 2, 2022 | 01:00 PM
Run to Rund's Avatar
I have gotten surprisingly good results with Rustoleum hammered copper 210849 rattle cans on cast surfaces.
Old Oct 2, 2022 | 04:05 PM
MAW's defined. I should have known. After 30+ yrs driving this car while incrementally restoring it, I have fallen into that rabbit hole way too often.
I've read in some threads good things about Bill Hirsch Old bronze paint, brush-able or spray-able, that is what I'm considering for this MAW project. Spray the easy parts like valve covers, and brush this rest from the same can of paint.... Should match right? Just wondering about how the brushed paint looks. If anyone has done this and can let me know, I'd sure appreciate it.
Old Oct 2, 2022 | 06:16 PM
The spray actually makes it easier to reach the hard-to-get tight spots. IMHO, (In my humble opinion)
Old Oct 3, 2022 | 05:03 AM
allyolds68's Avatar
I removed everything and sprayed mine with the engine in place. The only places that were tough to get decent paint on were around the starter and around the motor mounts (I should have removed the starter). You'd be amazed at how much room you have when you get everything off the engine and remove the radiator
Old Oct 3, 2022 | 06:23 AM
Rocketguy's Avatar
Any paint you buy in quart or pint cans can be brushed on. Getting it to the correct viscosity may be required.
Old Oct 6, 2022 | 06:40 AM
Ozzie's Avatar
I used Rust-oleum High Heat Ultra 241232 Aged Copper. It was a good match to the original. Unfortunately, it was only available as a spray can. If you want to brush, you can spray it into an open container. If you want to see how it matches, here it is next to the original.
Rust-oleum sample on bottom; original Olds paint on manifold on upper
Old Oct 6, 2022 | 06:59 AM
allyolds68's Avatar
I tried Aged Copper and it wasn't even close to the 68-69 original bronze but it was closer to the earlier 65-66 bronze.
Old Oct 6, 2022 | 07:51 AM
Rocketguy's Avatar
I'd really like to see a video of that
. . . . . . only available as a spray can. If you want to brush, you can spray it into an open container.
Old Oct 6, 2022 | 09:41 AM
Andy's Avatar
Exactly what I used, painted engine in the bay, plastic bags, tin foil and masking tape make it pretty doable. Like Dr said, pull valve covers, do them separately..if using rustoleum bronze spray a satin high heat clear coat over it.
wisniows
Paint
28
Sep 23, 2017 10:16 AM
67Rocket
Dec 18, 2015 08:11 AM
Olds/uk455
May 8, 2013 11:18 AM
vistaride
Oct 29, 2012 07:36 PM
gbodyfan
Paint
Jul 27, 2010 04:38 AM
