1971 442 Axle Ratios
Old May 20, 2024 | 02:48 PM
bcrocket's Avatar
My ‘71 Convertible has the THM 400 Automatic and Limited Slip differential. What was the standard axle ratio for this car? And what were the optional ratios? OR where may I find this information?
Thanks!
Old May 20, 2024 | 03:13 PM
v8al's Avatar
Registered Olds Owner
Refer to the 1971 Info Kit from GM pg: 170 and pg: 182 (From the GM Heritage Archive)
Old May 20, 2024 | 03:16 PM
Also available by searching the forum. Here's an old thread with the same information:
https://classicoldsmobile.com/forums...-ratio-110849/
Old May 20, 2024 | 05:37 PM
bcrocket's Avatar
bcrocket's Avatar
Thanks, all - I tried the search bar and got nothin’ - user error no doubt.
Old May 20, 2024 | 06:06 PM
Maybe not - I found that with a Google search using “site: classicoldsmobile.com ratios”.
Old May 21, 2024 | 04:33 AM
GEARMAN69's Avatar
Thanks!
Considering you won't know if you have the STD ratio or an optional ratio just asking blindly like there is only one answer is not the way to do it.. Get off the couch and get under your car with a jack and put in neutral and since its a Anti-Spin as you say simply count the yoke turns to one wheel revolution . I like to use the valve stem as a pointer down to start and count yoke as it turns 180 degrees at a time so say 2.5 turns well 2.56 .... 3-1/4 turns well 3.23 , etc not brain surgery and see if ya can find the code stamp on the right side axle tube while your there and maybe it matches what you find
Owen Miller
Oct 13, 2021 04:35 PM
Jul 2, 2020 03:28 PM
clessard
Drivetrain/Differentials
Nov 11, 2019 05:05 PM
dc2x4drvr
Jun 23, 2018 07:17 AM
trevor1400
Dec 27, 2016 12:09 PM
