1971 Cutlass B – 350 – factory standard rear axle ratio?
Old Dec 16, 2016 | 02:01 AM
trevor1400's Avatar
Sorry for my question if I haveoverlocked the answer in the forum.
Do you know which standard rear axleratio for a 1971 Cutlass Base – 350 – TH350 was delivered from the factory?
Thank you and
regards
Trevor
Old Dec 16, 2016 | 06:18 AM
monzaz's Avatar
fatory ratio
could really be any thing...
likely with that stock combo a 2.73 or 2.56 will be most common.
Old Dec 16, 2016 | 06:27 AM
My car came with 2.56.
Old Dec 16, 2016 | 07:33 AM
The Salesman's SPECS booklet tells you EXACTLY what the standard axles were for each drivetrain combination, as well as the available options.
For the Cutlass line in 1971, the standard axle ratio with TH350 and 350 2bbl (RPO L65 motor) was 2.56:1. With the L74 350 4bbl motor it was 2.73:1. Note that in the Cutlass Supreme line, standard axle was 2.56:1 with either of those motors.
Old Dec 19, 2016 | 09:24 AM
monzaz's Avatar
details
Yep, That is what is should be...But you know how the factory lines went... KEEP THE LINE MOVING. You never know unless you dig into the rear physically.
Jim
J D
Old Dec 27, 2016 | 12:09 PM
trevor1400's Avatar
Thank you for all the answers.
Now it's clear, my Cutlass has 2,56:1....
Best
Trevor
twilightblue28A
Drivetrain/Differentials
Apr 9, 2016 07:13 AM
halfmoontrail
Jul 1, 2011 09:08 AM
HouTXCutlass
Suspension & Handling
Jan 13, 2010 07:41 AM
mutzi
Jul 16, 2009 05:04 AM
