Another O-type question
Old Dec 27, 2016 | 04:09 PM
oldsmobilty's Avatar
I have a 70 O-type with 2:56 gear. I bought the Richmond 3:42 gears and the spacer. Has anyone put one of these together? Is there anything to look out for or be aware of?
Old Dec 28, 2016 | 10:19 AM
Magna86's Avatar
What spacer are you talking about? You cant mount the 3.42 gear on the 2.56 carrier and make it work. Buy a new production posi for it. Jim Monzaz or Brian Trick from here can get you what you need.
Old Dec 28, 2016 | 10:31 AM
This question is for someone that is familiar with the process. The 3:42 gear will mount to the 2:56 carrier. You can research it on this website. I did buy the spacer and obtained the basic knowledge of this from Brian Trick. Thanks
Old Dec 28, 2016 | 10:49 AM
https://classicoldsmobile.com/forums...ar-spacer.html
Old Dec 28, 2016 | 11:26 AM
joesw31's Avatar
Measure all of the shims when you taking it apart, and make sure everything de-burred. And most of all take your time.
Old Dec 28, 2016 | 01:22 PM
I'm assuming you also have the appropriate bolts for use with the spacer. Other than what has been said about deburring, it's the same as any other ring and pinion installation.
coldwar
Feb 20, 2014 01:09 AM
L77F85
Drivetrain/Differentials
16
Nov 29, 2013 06:19 AM
2blu442
Body work
Feb 6, 2009 04:36 PM
petritl
Sep 8, 2008 10:45 AM
olds1968
Jan 24, 2008 07:35 AM
