12 bolt o axle
Old Dec 24, 2016 | 08:48 AM
l69gm's Avatar
12 bolt o axle
I just purchased a 12 bolt o axle with 278 gears.Will 3.23 gears work since its a 2 series??
Old Dec 24, 2016 | 09:30 AM
oldsmobiledave's Avatar
No
No. OEM 3.23 won't go on 2.78 carrier.
2.56 & 2.78 same carrier
3.08 & 3.23 same carrier and aftermarket 3.42-3.90-4.10
3.42-3.91-4.33-4.66-5.00 same carrier
Old Dec 27, 2016 | 01:38 PM
l69gm's Avatar
12 bolt o axle
Thanks for the info....Is the 3 series carrier out of a 12 bolt chevy rear different than the o axle?Thanks.
Old Dec 27, 2016 | 01:53 PM
junior supercar's Avatar
yes
Old Dec 28, 2016 | 10:25 AM
Magna86's Avatar
You need a 3 series carrier from another O type or you can buy a new production posi. But not sure how they work with 3.23 gears. They should work fine since the 3.42 and 3.90 richmond gears are made to work on a gm 3.08-3.23 carrier.
Old Dec 28, 2016 | 11:23 AM
joesw31's Avatar
Yes, you will need a spacer.
Old Dec 28, 2016 | 02:01 PM
l69gm's Avatar
Ok,Thanks for the info.
Old Dec 29, 2016 | 04:42 PM
monzaz's Avatar
Spacer for 12 bolt O type
We make custom ring gear spacers for the o type rear if you need. Jim
J D
Old Dec 31, 2016 | 10:21 PM
11971four4two's Avatar
MOTORHEAD
Ratio
I have a 342 in the car now
have a 391 on the floor
spendy
72442conv
Mar 19, 2012 07:14 AM
cutlasssupreme71
Drivetrain/Differentials
Feb 22, 2011 11:40 AM
dan1s
Sep 23, 2008 01:53 PM
m42665
Mar 27, 2008 06:57 PM
dan1s
Mar 16, 2008 11:13 AM
