Looking to purchase a 67 442 question
Old Dec 18, 2023 | 07:39 PM
Kjbn's Avatar
I am looking at purchasing a 67 442 convertible with VIN 33677z121523. Where can I get information to decode the VIN? And should I learn how to decode the cowl tag. Have not owned a 442 in the past.so I am new to this and would like to understand where to learn more.
Would like to make sure I am buying a true 442 with the correct drive train and options?
Thank you.
Old Dec 18, 2023 | 08:26 PM
66-3X2 442's Avatar
Thank you.
That will be a Fremont,Ca built car and none of the option codes will be on the cowl tag. It will have color of the car,interior color etc. but nothing telling it's a 442 or not.
Old Dec 19, 2023 | 06:14 AM
69CSHC's Avatar
It's not a 442, a 442s vin number must start off as 338 for 1967.
As 66-3X2 442 mentioned its a Fremont car, Code Z in the vin. Because the real 442s that were built there are virtually unverifiable. It's the go to vin code for fakes.
Old Dec 21, 2023 | 12:56 AM
Thank you.
Your first problem is that the VIN you posted isn't a valid 1967 Oldsmobile VIN. You are missing a character, as the VIN is 13 characters long. It is either 336677Z121523 or it is 338677Z121523. This is important since only the latter of those can possibly be a 442 (however this VIN alone is not a guarantee). The other problem is that since this is a Fremont, CA car, the 5V code on the cowl tag that proves the car is a 442 was not used by Fremont and thus there is no way to prove the car is really a 442. Of course, if the VIN is really 336677Z121523, then it cannot be a 442.
Olds45570
Sep 18, 2022 04:06 PM
Roger60
Jan 10, 2020 03:58 PM
cincyrick67
Feb 4, 2016 06:06 AM
springbryan
Apr 26, 2014 04:27 PM
Double D Farms
Sep 8, 2007 05:28 PM
