Rear axle..
Old Sep 27, 2023 | 09:10 AM
Tancuda's Avatar
Rear axle..
Hi again, Can you tell which differentiel is this, i'm a bit confused, it's on my friend's 71 442 (455cu), I need to order axle bearing,
it's a 10 bolts for sure. Need to know if I have to remove cover to take out the "C" clips in order to remove the axle.
Thanks a lot
Old Sep 27, 2023 | 09:24 AM
Tancuda's Avatar
Here's a little side shot..
Old Sep 27, 2023 | 12:55 PM
See the block "O" on the front face of the center section between the ribs? That definitively identifies it as a 8.5" 10 bolt rearend used in the '71-'72 model years.
Axle bearings should be SET9. Be aware that some of the oil seals are not the correct thickness. Monzaz has posted about this a lot: 712146 SEAL IS SUPPOSE TO MEASURE .490
Search the forum for his posts before buying parts. Or just buy the parts you need from him directly.
Old Sep 27, 2023 | 03:52 PM
Tancuda's Avatar
Thanks for the info, the one at Rockauto are 0.375 width, if I use that, I suppose there will be a leak or ?
The spec for Timken seal 712146 are 0.470 not 0.490 : Part Number 712146, Oil Seals Inch On The Timken Company
For the bearing, are National A9 ok ?
Old Sep 27, 2023 | 04:53 PM
Tancuda's Avatar
Just came across those, they are 0.470 width : RockAuto
VI Cutty
Drivetrain/Differentials
20
Sep 12, 2023 12:31 PM
Owen Miller
Oct 13, 2021 04:35 PM
RetroRanger
Oct 19, 2012 07:09 AM
brown7373
Apr 30, 2012 06:41 AM
TripDeuces
May 13, 2011 06:45 PM
