Brake booster..
Old Sep 27, 2023 | 04:00 PM
Tancuda's Avatar
Brake booster..
Hi again, on a brake booster if I use a hand vacuum pump to simulate engine vacuum on the booster, I suppose it should hold vacuum right ?
I did that and it doesn't hold, the hose and check valve are ok. The brake pedal travel is very short and pretty hard.
Thank you
Old Sep 27, 2023 | 04:01 PM
Chances are your booster is bad.
Old Sep 27, 2023 | 04:36 PM
442Harv's Avatar
You do have to pump it a lot , did you give it a good try?
Old Sep 27, 2023 | 04:49 PM
Tancuda's Avatar
Thanks, well pretty good, but maybe there's a better way to test it
Old Sep 27, 2023 | 06:32 PM
With a bright flashlight, can you visualize any leakage/seepage from or around the booster? It could be a tell tale sign but still if no leakage/seepage it doesn't rule out a bad booster.
Old Sep 27, 2023 | 08:02 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Can you hear it with the engine running?
The seal between the master and booster may be leaking.
Old Sep 28, 2023 | 02:22 AM
Tancuda's Avatar
Yes I could try that, thanks
Old Sep 28, 2023 | 02:25 AM
Tancuda's Avatar
I can't start it because I'm waiting for the fuel line, but I will do that, thanks
rberndsen
Brakes/Hydraulic Systems
Aug 23, 2023 08:18 AM
piperman60
Jun 24, 2021 01:19 PM
moranj2
Nov 25, 2018 05:29 AM
foulpalamont
Sep 14, 2018 05:30 PM
smcurro
Oct 14, 2011 12:55 PM
