'69 Olds H/O 455 4v valve train
Old Jul 14, 2025 | 09:19 AM
alsmith787's Avatar
Need some help looking for recommendations on valve seals - keepers - springs (brand - part numbers improvement products to consider) I've got a leaking seal in cylinder 4 (fouled plug) everything else on engine is fine; just in case I find something when I open it up need to have some parts just in case. Thanks
Aldith787
Old Jul 14, 2025 | 10:22 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
You are confident it's the stem seal not ring seal?
Are you doing this with the heads on or off?
How many miles/years on the heads?
If you trouble shot and are confident it's the seal, I'd verify the guide clearance before moving forward.
If the guides are gone, you are wasting your time. Time for a head refresh.
Comp Cams is a good source.
They will need to know the OEM cam profile.
If you can find the OEM spring rate, that's good info. I'll assume you are replacing all seals, keeps & springs.
esisson
Jun 7, 2023 07:44 AM
briane
Nov 12, 2021 02:13 AM
Freddy B
Sep 16, 2014 06:44 AM
MaxDog
Feb 27, 2012 08:12 PM
Lady72nRob71
Jul 14, 2011 07:24 PM
