Choke Ideas for a 68 442 with Edelbrock intake
Old Jan 27, 2026 | 06:26 PM
442craig's Avatar
Hi all,
I'm sure this has been covered before, my apologies! What are my options for a divorced choke set up on my 68 442 with stock Q-jet and Edelbrock Olds performer intake manifold? I figured I will have to run a cable thought the firewall. Any other cool options?
Thank you in advance!
Craig
Old Jan 27, 2026 | 06:35 PM
2blu442's Avatar
You could swap over an electric choke on the carburetor. I know Joe P. made a post suggesting how to wire one up. John
Old Jan 27, 2026 | 07:20 PM
Electric choke conversion:
https://www.carburetor-parts.com/cho...EjDFDsJ91hErUs
Old Jan 27, 2026 | 08:10 PM
John - Here is the URL link to Joe's thread...
Electric choke wiring
Old Jan 28, 2026 | 08:29 AM
The original carb has the linkage for a divorced choke, so the conversion to electric on that carb body is quite a bit more involved. The easiest way to do this is to get a 1970 Olds Qjet with the hot air choke, jet it to match your original, and swap the hot air choke coil for an electric one.
Old Jan 28, 2026 | 11:06 AM
allyolds68's Avatar
This was a thread from about 9 years ago when I had a similar (not exactly the same) question. I ended up going with a 70+ Q-Jet and an electric choke
https://classicoldsmobile.com/forums...-q-jet-119021/
Old Jan 28, 2026 | 11:49 AM
Definitely consider getting a different Quadrajet with a hot air choke. You wouldn't want a manual choke on your Oldsmobile, that's the same thing lawn mowers have.
When was the last time Oldsmobile sold a car with a manual choke? Before WW2?
Old Jan 29, 2026 | 07:45 AM
442craig's Avatar
Thanks guys! You always come through! Maybe down the road I'll consider swapping the carb. What about just running a manual cable through the firewall? Some type of electric servo would be slick too. Maybe a business idea?
Again, Thank you!
Craig
Old Feb 27, 2026 | 05:05 AM
techg8's Avatar
Everyday Performance LLC makes and sells carburetor mounted electric choke conversions for divorced choke quadrajets.
For Oldsmobiles, The whole choke bracket gets swapped out for one with the electric choke device preinstalled.
An EdpLLC COMPLETE UNIVERSAL ASSEMBLY Electric choke conversion kit WITH PIN
Old Apr 11, 2026 | 09:20 AM
442craig's Avatar
Very interesting! Thanks Ken
Grandpas_cutty
Apr 3, 2025 04:45 PM
AJFink
Jul 6, 2016 08:26 AM
deadeyejedi
Aug 28, 2015 05:41 AM
tgilligan
May 18, 2013 08:32 PM
mitsudave
Feb 26, 2007 12:30 AM
