Help decoding 1968 engine code and verifying if 442?
Old Jul 25, 2023 | 10:06 PM
tsherm65's Avatar
New owner 1968 442/new to the forum. I'm looking for some help verifying if engine is original to car as told when purchased; said it was 400 cu in. Based on the research I've done for the block to be original on the pad it would read 38××××××× with the last seven matching the Vin. So Vin 344778M101339 should have 38M101339 on the block pad, correct? I think that matches though tough to read. Then looking at the heads, the code appears to be 394548 with code C; if I researched correctly those are heads for a 425 or 455 cu in though. So possibly original block with NOHs? Thanks in advance for any assistance
C head?
head 394548 does this equal 425 or 455? engine supposed to be 400
block stamp, a little difficult but looks to be 38 and 101339 at end..dont see the M in between but would need to clean?
Old Jul 25, 2023 | 10:46 PM
C heads were used on the 400, 425, and 455 engines from 1967 to 1969.
Old Jul 26, 2023 | 03:34 AM
The block casting number will tell you what the block is.
Old Jul 26, 2023 | 05:29 AM
tsherm65's Avatar
Great..ill get a photo. Looks like 396026G...400 block?
Old Jul 26, 2023 | 05:30 AM
tsherm65's Avatar
OK great - thanks @Fun71for the info!
Old Jul 26, 2023 | 07:04 PM
Yes, that's exactly what it is. C heads are factory-issue for that block.
Scottsand1983
Jun 19, 2017 06:03 PM
my71olds
Apr 7, 2013 05:44 PM
1970supremevert
Jan 20, 2013 12:59 PM
Polebridgemt
Dec 5, 2012 06:16 PM
rida142
Jul 22, 2007 09:25 PM
