Tail pipes
Old Aug 13, 2022 | 05:19 AM
New2oldsw30's Avatar
Tail pipes
Looking for GOOD fitting tail pipes for a 1970? Possibly 3". Not worried if I need to step them down for the tips.
Thanks John
Old Aug 13, 2022 | 07:03 AM
442Harv's Avatar
I think you can buy 3 inch tips, Google them.
Old Aug 13, 2022 | 09:16 AM
Yes I seen that you canbuy the tips in 3" and there actually cheaper then 2 5 tips.
Just like a nice fitting tail pipe.
Old Aug 13, 2022 | 09:39 AM
www.gardnerexhaust.com
Old Aug 13, 2022 | 09:50 AM
Doesn't look like they sell just tail pipes? Just says systems.
Old Aug 13, 2022 | 09:53 AM
Call them. I bet they can accommodate you. Their stuff is supposed to be the best, but it's spendy.
Old Aug 13, 2022 | 11:29 AM
Tri-Carb's Avatar
Based upon my own experience, Eric will not sell you pieces of a system, but I like Gardner and they do great work.
Old Aug 13, 2022 | 12:30 PM
tnswt's Avatar
'70 4-Speed W Machine
^^^^Exactly^^^^
When I purchased my car it came with a Gardner system, a piece needed to be replaced. Eric asked for a picture of the pipes coming off of the exhast manifolds as there is a special kink or bend they put in their pipes that ID their system. I passed that part of the test, next, he wanted to see a receipt, which I didn't have....no va, said I had to purchase a complete system since I was not the original purchaser.
Old Aug 13, 2022 | 07:41 PM
skekas33's Avatar
Call John at Waldron Exhaust in Centreville, Michigan. 269-467-7185. He made me an all stainless exhaust for my 1967 442 that fit absolutely perfect. Great guy to do business with and considerably cheaper than Gardener. I have never done business with Gardener but I hear they make a fantastic system, however I can not say enough regarding John's willingness to work with the customer.
Old Aug 13, 2022 | 09:11 PM
redoldsman's Avatar
Proud Viet Nam Veteran
I used Waldron for duals on the 54 I had. The left exhaust pipe had to make some strange bends around the power steering, but it fit perfect.
Old Aug 13, 2022 | 10:14 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
John,
Unless you are running 1000hp you don't need a 3" exhaust, way overkill. Could actually hinder performance
2.5 will be more than enough. Many places will sell pieces of the 2", 2 1/4", or 2 1/2" systems. Plus the trumpet tips look better (IMO) at 2 or 2.25"
2.5 and 3s just don't do it for the OEM look...for me.
Suggestions:
Make sure you tuck the tailpipes up in the trunk quarter drop-offs. We shouldn't see any of the system when viewed from the side of the car.
Make sure the tips exit the correct length through the bumper.
If it's not a 442 we shouldn't see the baloney cut, downturn tailpipes extend beyond the bumper.
Too many times a butchered exhaust is visually unpleasing and makes it look cobbled.
Old Aug 14, 2022 | 03:59 AM
Tri-Carb's Avatar
Waldron provides great exhaust for the widest range of cars. But, the last time I checked, they do do provide correct pipes for those Olds with factory chambers (dimples). Likewise for the associated factory clamps and tips. If those features are applicable to a car and important to you, Gardner is the only choice. If and when someone buys Walt V’s tooling, this could change.
Old Aug 14, 2022 | 12:56 PM
Will look into Waldron.
I'm leaning towards 3" due to the math that true 2.5 duals are in the 500 to 550Hp range. That is where I'm hoping to be. Maybe more maybe less. Usually 2.5" stuff is easy and plentiful, but 3 and up gets scares. WILL be 3" from headers, x pipe and in & out of muffler. So if I can't find 3" tail pipe, could always step down to 2 5.
Just research now for fall winter redo.
Old Aug 14, 2022 | 03:08 PM
Waldron sells reproduction stock pipes. You won't get 3" pipes from them.
Old Aug 15, 2022 | 09:48 PM
herkguy's Avatar
I have the Pypes 2.5" and i would give them 97% plus..need just a little massaging and critical your mufflers are at correct height or they will just clear the frame as they come back in inside the qtrs.
Old Aug 16, 2022 | 04:26 AM
Thanks, that the type of info I need to hear.
I know they offer 3" trumpets, now just finding the pipes that run up to them will be the issue.
Old Aug 16, 2022 | 05:22 AM
Tri-Carb's Avatar
The Parts Place Inc offers some low priced exhaust systems. I suspect these are made by a major supplier like Pypes and may be drop shipped direct to their customers. I have no information regarding quality, fit and the like.
Old Sep 10, 2022 | 05:47 AM
Well update:
I can't seem to source a good direct fitting tail pipe for a 1970 W30 with tips? I'm sure there out there, I just can find them and still looking. Looks like I will be calling Waldron and discussing with them??? Also talking to locals about just bending some up????
Got the new headers in with 3" collector. So will be 3" with x-pipe and Turbo/Super Turbo muffler, probably 20 to 24" long case. Going to set-down to 2.5's tail pipe running to bumper.
Old Sep 10, 2022 | 07:03 AM
Waldron makes stock exhaust systems. That's a 2" tail pipe. All of the aftermarket 2.5" tail pipes are for Chevelles and generic A-body applications, not intended to line up with the notches.
Old Sep 10, 2022 | 09:26 AM
You can take your car to muffler shop and have them fabricated.
Old Sep 10, 2022 | 09:30 AM
Assuming that 1) you can find a muffler shop that actually bends pipes anymore, and 2) you're OK with the non-mandrel bends you'll get. Frankly, buying existing A-body 2.5" mandrel bent pipes and making minor tweaks to them is likely a much less expensive and restrictive option.
Old Sep 10, 2022 | 09:59 AM
You're also assuming the flow within the muffler and that it's a true 3" not stepped down to 2.5 internally. I doubt you'll notice much power difference with non-mandrel bends. Below is a good chart for estimating exhaust tubing size.
Old Nov 7, 2022 | 06:02 AM
Ok back at it. Found these from Flowmaster 3" tail pipe kit 15818. Any ideas it's car building season and need some insight as I'm doing 3+ cars this winter......
https://www.summitracing.com/parts/f.../442/year/1970
bigdooly
Nov 21, 2021 07:28 AM
rr69ho
Sep 17, 2018 04:14 PM
olds 307 and 403
Jun 27, 2017 02:57 PM
Cincinnati Rick
Apr 9, 2017 06:42 AM
lemoldsnut
Aug 28, 2015 12:26 PM
