I ordered new rubbers for the radiator and control arms from Fusick. The left radiator rubber was good but the right one was too big and needed some massaging to fit. I got the rubbers for the bottom front of the inner fenders with the set. The left one was easy to install as I had the steering gear removed. The right one needed some arm squeezing to get it installed and the push clips installed. I removed the old control arm rubbers (they were very hard) and then removed all of the staples from the inner fender. Wow, those were some real tough steel staples! I then installed the rubbers with the supplied push clips. The back hole of the bottom rubbers lines up with the front hole of the a arm rubbers. The bottom rubbers have the push clips installed from the inside and the a arms are installed from the outside. I installed a 1/4" bold to connect the two rubbers to the fender. All of the fender rubbers fit perfectly.
Photo #1 shows before
Photo #2 shows installed
Photo #3 shows where I bolted the two rubbers together.
