67 442 Installed new upper A arm rubbers
Old Jun 6, 2025 | 03:30 PM
425HP409's Avatar
Restorer
I ordered new rubbers for the radiator and control arms from Fusick. The left radiator rubber was good but the right one was too big and needed some massaging to fit. I got the rubbers for the bottom front of the inner fenders with the set. The left one was easy to install as I had the steering gear removed. The right one needed some arm squeezing to get it installed and the push clips installed. I removed the old control arm rubbers (they were very hard) and then removed all of the staples from the inner fender. Wow, those were some real tough steel staples! I then installed the rubbers with the supplied push clips. The back hole of the bottom rubbers lines up with the front hole of the a arm rubbers. The bottom rubbers have the push clips installed from the inside and the a arms are installed from the outside. I installed a 1/4" bold to connect the two rubbers to the fender. All of the fender rubbers fit perfectly.
Photo #1 shows before
Photo #2 shows installed
Photo #3 shows where I bolted the two rubbers together.
Sugar Bear
Suspension & Handling
Dec 6, 2024 11:01 PM
Upstate 442
Mar 30, 2023 01:07 PM
johnnyrockets
Jun 22, 2019 06:50 AM
oldzy
Dec 19, 2011 06:43 AM
oldzy
15
Feb 4, 2011 06:58 PM
