Anyone recognize this brand of control arm?
Old Mar 28, 2023 | 02:30 PM
Upstate 442's Avatar
Anyone know who makes this?
Old Mar 28, 2023 | 04:53 PM
Maybe if you attached a smaller photo? Seriously, a better photo, and pa picture of the shaft end of the arm would help you get a useful answer.
Old Mar 29, 2023 | 03:51 PM
Updated photo
Old Mar 29, 2023 | 05:12 PM
Again, it would help to see what the shaft looks like.
Old Mar 29, 2023 | 05:20 PM
They are similar to but not exactly the same as Hotchkis 1103C.
Old Mar 29, 2023 | 06:20 PM
Similar....
https://switchsuspension.com/oldsmob...part-11223699/
Old Mar 30, 2023 | 07:45 AM
Thanks for the replies. Will post pic of the shaft.
Old Mar 30, 2023 | 07:52 AM
They might be an older version of the Hotchkis arms.
Old Mar 30, 2023 | 08:00 AM
^x2^
I thought same.
Call Hotchkis. 1.877.466.7655
Old Mar 30, 2023 | 08:07 AM
Thank you! Will do.
Old Mar 30, 2023 | 08:53 AM
therobski's Avatar
I'm guessing -these Hotchkis parts are about 10 years old now give or take. This may give a clue- but take note these control arms are a tall spindle ( B-spindle) upgrade. The steel used in Hotchkis parts are real beefy and heavy compared to whats out there.
Old Mar 30, 2023 | 10:43 AM
Just got off the phone with Hotchkis. They confirmed that the arms are theirs and approximately 15 years old. They still support their product and have parts available.
They also indicated that these were in fact the "B-body" arms that were commonly used on "A-bodies" for larger brake applications. Also require a 2nd Gen Camaro outer tie rod end. Super nice people at Hotchkis!
Thanks for all the help!
Old Mar 30, 2023 | 11:03 AM
therobski's Avatar
They are great people to work with. I used later GM parts- Z28 1LE rotors, Caprice calipers, B-spindles came from a Buick Estate wagon, tie rod ends from Buick GN. This conversion has had some of articles written about it but since then you have more choices in the aftermarket. I wanted as many GM parts as I could use on the conversion.
Old Mar 30, 2023 | 12:22 PM
You're absolutely correct, they are great people! Also, thanks for your input as is extremely helpful. Again, thank you therobski!
Old Mar 30, 2023 | 01:07 PM
therobski's Avatar
Yes sir...
sschevellecutlass_Bob
Suspension & Handling
Jan 7, 2022 01:34 PM
Seff
Jul 7, 2015 03:03 PM
1969cutlass4d
Jan 6, 2015 11:26 AM
Jetstar 88
Jan 30, 2012 05:14 PM
oldzy
Dec 19, 2011 06:43 AM
