Battery drain when car is off question
Old Sep 10, 2022 | 06:13 AM
ericisback's Avatar
Will a 1970 442 use the battery at all, when the car is off? Thanks.
Old Sep 10, 2022 | 06:18 AM
72455's Avatar
1972 U code Supreme
If you have a dash clock, yes, but the draw will be negligible. However, if your battery is dumping at at an abnormal rate, then you have a parasitic draw somewhere.
Old Sep 10, 2022 | 07:34 AM
In STOCK form, the optional clock is the only draw, as noted. If you have aftermarket stuff (stereo, USB power ports for your phone, etc) then all bets are off. That should STILL be a miniscule draw, but any aftermarket additions are suspect. How about you tell us more, like exactly what is different from how it left the factory?
Old Sep 10, 2022 | 09:21 AM
The battery over time will lose its charge naturally also.
Old Sep 10, 2022 | 10:15 AM
PatL's Avatar
Also be sure that your car has enough run time to keep the battery charged. Really needs to be more than just idling. I end up putting mine on a charger every once in a while, since I just don/t drive it enough.
Old Sep 10, 2022 | 11:18 AM
ericisback's Avatar
Car is completely stock, and the clock currently does not work, so I guess there is no draw.
The car is driven in a rotation with several other cars, so it does sit for extended periods. Thanks to all for the info.
Old Sep 10, 2022 | 01:14 PM
I keep most of my vehicles on a trickle charger, with quick-connects so that I can unplug and go with ease.
Old Sep 10, 2022 | 07:53 PM
Oldsguy's Avatar
Past Administrator
then you need to get out and drive it more! Enjoy that thang...
J1978
Dec 24, 2021 09:13 PM
Jon442
May 10, 2021 07:31 AM
Sugar Bear
Sep 18, 2020 12:41 PM
Neil Morrison
Feb 28, 2020 06:35 PM
rocketman77
Apr 24, 2016 03:44 PM
