72 442 clutch replacement
Old Jun 25, 2023 | 12:09 PM
woodeye3's Avatar
I have a few questions about replacing the clutch on my 72 442. It was a 350 auto. originally, and has been changed to an overhauled 455 and 4 speed.
I bought the car on BAT and have no way of contacting the guy who did the engine and trans swap.
It would appear, and I was told, that the car has very few miles sense the swap was done.
The pedal must be at the bottom of the travel to disengage. It takes quite quite a bit more effort to push down the pedal on mine than a friends 68 442 needs. It looks like the pedal assemblies and clutch linkage have been set up with new, probably aftermarket, parts. They work freely without any binding.
1. Any ideas on why it takes so much effort to disengage the clutch and why it would grab so low?
2. How can I tell if I have a 10.5" or 11" clutch before removing mine, so I can get a new setup if I need to replace mine without laying the car up for too long.?.
3. Is a 3 finger, or a diaphragm style clutch best.
4. Where is the best supplier to get the clutch kit from.
Thanks Jeff
Old Jun 26, 2023 | 05:59 AM
dc2x4drvr's Avatar
Welcome.
Has the clutch pedal freeplay been checked, should be 1” play at the top.
Old Jun 26, 2023 | 06:02 AM
woodeye3's Avatar
yes. the most i could get and still get clutch to disengage was about 1/2"
Old Jun 26, 2023 | 06:15 AM
fleming442's Avatar
Ok, someone explain why it needs 'x' amount of free play. Engaged is engaged; it doesn't matter how much play is in the pedal. DISengagement is more critical.
10.5 or 11 doesn't matter. Most flywheels I've seen have both sets of holes. Resurface before replacing.
I don't think 3 finger or diaphragm matters much, either. Diaphragms are allegedly smoother.
Old Jun 26, 2023 | 07:15 AM
dc2x4drvr's Avatar
A generic clutch fork can create problems along with the stud height in the bellhousing, I tried a “repro fork” didn’t work with stock (Olds) linkage. Also, throw out bearing, etc.
Gonna have to check everything, hope you have an Assembly Manual.
Old Jun 26, 2023 | 08:44 PM
There isn't any adjustment left in the clutch rod to the fork? A high force clutch is usually a sign of an aftermarket clutch. This can also alter the installed height of the pressure plate fingers, which would in turn create insufficient adjustment in the clutch rod. On one of my cars I had to use a longer aftermarket clutch rod to get the proper adjustment. I've found Centerforce clutches to be the best compromise of good clamping force without excessive pedal force.
Old Jun 27, 2023 | 01:27 AM
fleming442's Avatar
Once you own a McLeod, you'll forget all about the others.
Old Jun 27, 2023 | 05:41 AM
And yet, I had a McLeod before I went to Centerforce.
Seriously, this is like asking "what is the best muffler". Ask 20 people and you'll get 30 different answers.
Old Jun 27, 2023 | 06:29 AM
fleming442's Avatar
I fried 2 Centerforces; it looked like a bird's nest in the bellhousing. I also don't like the idea of little chunks of metal spinning around the way they're designed.
oldsmoboogie
Nov 28, 2021 09:06 AM
442gs
Jun 30, 2020 07:31 AM
Globeguy
Apr 29, 2017 10:25 AM
z11375ss
25
May 12, 2013 07:09 PM
mugzilla
Sep 7, 2009 05:57 PM
