Identification help on 68 442
Old Apr 25, 2025 | 08:30 AM
Tony4-4-2's Avatar
Hi there, I was sent to this site by some guys over at AACA. They said that my 442 might have been a w-30 that had the parts sold off it. Is there any way I can tell if it was? Also is it possible to get a build sheet for it? Something like the marti auto reports for the fords mabye? It was manufactured in lansing and sold in west virginia I believe. Thanks for the help!
Old Apr 25, 2025 | 09:28 AM
Hello.
The odds are it's not a w-30. A lot of people hype things for no reason. You can easily verify it is a 442, you can easily verify if it has numbers-matching parts. You can easily verify it is a Lansing car. There is a 1969 Lansing build sheet, but it is astronomically rare to find one in your car. It will have a digit for W-30, or whatever else it was. The broadcast card, which is more common, has nothing on it for w-30 that year.
So, unless you have the build sheet (not the broadcast card) or an original sticker or order form, we have to go with parts. Parts are used to disprove W-ness usually.
If an automatic, if it is a numbers-matching OW TH400, then you've got a W-30. OG means it is not. Non-numbers matching means we don't know.
Other than that: AC Car? Not a W-30. Highway rear end? Not a W-30. The more W parts it is missing, the more it is just a BS claim by "those guys" that it is a W-30.
Old Apr 25, 2025 | 09:34 AM
1626930There is a 1969 Lansing build sheet, but it is astronomically rare to find one in your car.
^^ Everything John (Koda) stated except I think he made a typo on the 1969 build sheet for a 1968.
Old Apr 25, 2025 | 10:01 AM
No, I just thought it was a 69 when I read the title. Dumb me.
I think in 68 there was an A and B sheet. The B sheet will say transmission. These are incredibly rare, and in 68, I don't think the broadcast card said anything about w-30 like in 69.
Old Apr 25, 2025 | 02:50 PM
Nope, those records don't exist.
Old Apr 25, 2025 | 03:33 PM
Tony4-4-2's Avatar
Hello.
Im told its stock 4 speed, havent verified myself but seems likely. No ac. It has the air lift rear suspension. The heads were swapped for J.
Also I have the protect-o-plate. Would that tell me anything?
Old Apr 25, 2025 | 04:38 PM
Unless -- and this is a very slim chance -- the car was originally sold in Canada. The you're golden because you can get a GM Vintage Vehicle Services report which will detail how the car was originally equipped.
Old Apr 25, 2025 | 09:14 PM
69CSHC's Avatar
Yes it will.
If you did have the Protecto-plate it would have the W30 engine code
https://classicoldsmobile.com/forums...w-30-a-129187/ Post #23
The Protect-O-Plate in 68 has the engine code.
https://classicoldsmobile.com/forums...w-30-a-140330/ Post #7
Old Apr 25, 2025 | 09:36 PM
Correct you are.
68442droptop
Apr 20, 2018 05:20 PM
DocWatson
Jun 23, 2016 10:07 AM
Vader
Apr 14, 2012 03:18 AM
ctrain22
Oct 26, 2008 03:22 PM
DR_DAN
Aug 22, 2006 02:14 PM
