72 Hood Hinges
Old Aug 1, 2023 | 01:31 PM
woodeye3's Avatar
72 Hood Hinges
Does any one know if you use the same hood hinges for a 72 all steel hood and a oem fiberglass/steel combination hood. The parts place sent me the ones
that are for the aftermarket fiberglass only hood.
Thanks Jeff
Old Aug 3, 2023 | 05:32 AM
herkguy's Avatar
My 70 used the same hinges and springs. The factory combo hood is not a light weight hood like an aftermarket straight fiberglass would be.
it’s still heavy.
I thought the aftermarket used the same hinge, but lighter springs. No expert though, hopefully a 72 owner will chime in.
what I have seen a lot of are aftermarket hoods using factory springs, when the hood is closed, there is a bulge/bow along the sides because it’s too much pressure. They don’t fit flush along fender.
Old Aug 3, 2023 | 05:39 AM
That bulge is due to poor workmanship of the hood, not the springs.
jjborgesi
Aug 15, 2016 09:17 AM
The Bug Man
Oct 31, 2013 08:10 AM
webby
May 16, 2012 09:25 AM
JimMorrisonFan67
Apr 16, 2012 07:55 PM
