PDA
View Full Version : Parts Wanted
Pages : 1 [2] 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88
  1. Wtb
  2. G Body frame pads
  3. 1972 olds cutlass radiator core support cover lid 4 core radiator
  4. Wanted- 73 442 4 speed reverse lockout assembly
  5. 72 Vista Cruiser
  6. HP/NASCAR Engine Block
  7. 66 F-85 rear quarter emblem
  8. Toranado alternator bracket
  9. NOS 69 4-Speed Shifter Boots
  10. '67 Cutlass Jack and Parts
  11. Rear seat Springs
  12. Notched Valve Covers Needed
  13. alternator brackets non AC / 72 442
  14. LF 70-72 Cutlass convertible frame
  15. 1964 Cutlass Trim Clip
  16. WTB: 68 Cutlass Sedan Passenger Side Power Rear Window Motor
  17. B85 Molding for ‘70-‘72 442 non-post
  18. 68 to 69 power antenna switch
  19. 1970 W-30 F Heads
  20. Wanted 72 wagon paint divider stainless
  21. Rubber flooring
  22. Milodon Windage Tray Studs 81219
  23. 1965 Cutlass side molding
  24. AC Delco NOS R44S Spark Plugs
  25. Need Timing Chain Set for Line Bored Block
  26. Kent Moore Type "O" Differential Rebuilding Tools
  27. WTB Olds 455 Shortblock
  28. 1970 W-30 Aluminum Intake
  29. 1973 hurst Olds exhaust tips needed
  30. .7850 ratio adapter. 90 degree for 72 4 speed
  31. 1963 dynamic 88 4door Holiday
  32. 69 Cutlass trim
  33. G body v8 frame pads
  34. 1970 W-31 throttle body
  35. WTB - 1970 3.23 posi rear end
  36. RH FRT lower control arm 71 442
  37. 54 to 56 Service Guild Training Manuals buy sell trade
  38. 68-69 Inner Fender Wells Cutlass/442
  39. 1972 cutlass S steering wheel - black
  40. 1966 67 Passenger Rear Quarter Needed
  41. 1966 9" brake booster
  42. 70f85
  43. LF Front lower control arms 72 Supreme Convertible
  44. SBO Thornton exhaust manifolds?
  45. Quarter windows bracket
  46. 69 Cutlass rear taillight bulb sockets
  47. 70-72 Glove Box "442" Emblem
  48. 1968 Cutlass/442 Front Bumper
  49. Looking for 80psi oil sending gauge 1970
  50. Looking for 455 headers and aftermarket heads for a 71 cutlass
  51. 1969 Cutlass 350 4bbl Carb
  52. 1969 N34 wheel
  53. 1970 4 spoke blue horn cap
  54. 65 olds cutlass hood wanted
  55. WTB: Power Feed Wire Horn Relay to Heater Relay
  56. 68-69 442 drive shaft
  57. W-30/W-31 Valve Springs
  58. Wanted 70-72 Vista bumper jack hook
  59. 1964 cutlass straight e-brake pedal shut off switch
  60. sidewinder tachometer mount and or tachometer with mount
  61. Still looking for a few N98 rims
  62. 1968 Cutlass/442 post coupe B pillar interior moldings
  63. 70 carb 7040258
  64. Type O Pinion Yoke wanted.
  65. 1965 Cutlass/442 fuse block
  66. 70 3:42 rear end
  67. Linkage
  68. WTB: 1949 TO 1956 15 Inch diameter rims
  69. WTB: 1954, 55, 56 Air Conditioned fan and fan shroud
  70. Looking for ‘72 Vista Cruiser middle seat
  71. Looking for 12 bolt oldsmobile pinion Yoke (s) 27 spline 1967 -1970 era
  72. 69-72 Vista Cruiser Tailgate
  73. ISO 15" X 7" Rally Wheels bolt on centers
  74. 68-69 cutlass/442 rear window lip
  75. Turn Signal Light/Harness, Horn - 66 442
  76. 1971-72 olds 455 W-30 aluminum intake
  77. GM Brake hose 1230992
  78. 1969 distributor
  79. One 1978 Toro hubcap
  80. 69 Deluxe Wheel
  81. 72 Supreme window fuzzies
  82. Hydramatic Jetaway parts needed please.
  83. Brackets and pulleys
  84. NOS 71/72 Supreme hardtop 2 door decklid
  85. Later model alternator belt tensioner gardware
  86. WANTED - 70' - 72 Dual Gate Parts.
  87. 64-66 442 Floor Shift
  88. 1971 or early 1972 Olds A body built rear axle
  89. Vista Cruiser
  90. 69 Ignition Switch Lock
  91. Part wanted please.
  92. 8-track wire connector - ‘67-‘72 (?)
  93. 1983 Olds V8 5.0L 307ci Fuel Pump Eccentric and Camshaft Bolt and button and Spring
  94. NOS or refurbished Rearview Mirror
  95. 66-67 A body Nos door revel molding
  96. 1956 Olds 88 linkage
  97. 1970 Hood Help
  98. 1969 hood release bell crank olds 442
  99. OLDS 5.7L DIESEL Parts
  100. Olds 403 value covers
  101. NJ Pa De Olds 350 Crankshaft
  102. Wanted... 55' Horn insulator...
  103. 66 cutlass ignition lock cylinder
  104. 75 Olds Cutlass Speaker/Defroster dash bezel
  105. Ring Clamp for remote power antenna NEEDED
  106. 1970 442 rear bumper braces
  107. NOS 1968 442 inner eye brows and fender end peak moldings
  108. Wiper switch
  109. Left and right plastic ac vents 67 cutlass
  110. 1970 442 lower a/c vent.
  111. Brass freeze plugs for Oldsmobile heads.
  112. Wanted Fuse Block 73-75 Cutlass
  113. Vacuum port connectors
  114. Wanted 1968-69 D Heads
  115. Wing Nut 1970 original only chrome
  116. 67 Cutlass Power Steering Pitman arm
  117. WTB 76 77 Cutlass Air Intake Snorkel
  118. 65/66 Delta Starfire Core Support
  119. Rear Brake Shoes 11×2.5 for 1967 Oldsmobile 98
  120. 75 Cutty Radiator Fan Shroud
  121. Wanted 15x7 rally II wheels 5x5 bolt pattern
  122. Wanted console shifter
  123. Wiring harness
  124. 69 cutlass
  125. Front fender needed
  126. Non-Console Manual Trans Level for '70 to '72
  127. 1968 Cutlass mirror
  128. 1970 442 4 speed radiator
  129. 65 cutlass tail light sheet metal
  130. Good used hood
  131. exhaust manifold
  132. WTB small block heads
  133. Radiator lower support bolts
  134. 1970 442 hardtop rear window trim
  135. Need water pump pulley for 82 Delta 88 with 3 grooves
  136. 1970 455 E Heads in Chicagoland Area
  137. WTB 1970 Cutlass Supreme Legendary Black Interior
  138. WTB 1970 Cutlass Supreme Black Bucket Seat Headrests
  139. WTB 1970 Cutlass Supreme Hood Extension Moldings
  140. WTB 1970 Cutlass Trunk Moldings
  141. WTB 1970 Cutlass Supreme Wheel Opening Moldings
  142. WTB 1970 Headlight Assembly Housing
  143. WTB 1970 Cutlass Supreme Grilles
  144. WTB 1970 Cutlass Supreme Hood Spear
  145. Valve covers
  146. 1959 98 Sedan
  147. Wanted 70-72 full set of black seat belts
  148. 69 center console parts
  149. 64 olds super 88 trunk letter "M" and vent knobs
  150. Wanted Edelbrock 2711
  151. Wanted 1970 Super Stock I rim
  152. Wanted Small Hurst Olds Badge
  153. Metal Headliner Trim
  154. Motor Search Near Los Angeles - 350
  155. WTB: TCS valve and Water pump for 72 Olds 350
  156. WTD: tail light lens gaskets 67 Cutlass Supreme
  157. Water pump core
  158. 66/67 drivers rear post coupe glass
  159. 1970 6 blade 18 inch olds fan
  160. WTB - Clean 1100879 '70 Cutlass 37 amp alternator..core, etc
  161. 55' 324 Oil filter adapter...
  162. Wanted - Swivel Bucket seat Knob 75 Olds Cutlass
  163. Need 66 442 open element air cleaner
  164. 15x7 SSll-SSlll wheels
  165. 1966 442
  166. WTB Woodgrain aka "Transfer" 1154210
  167. 1971-72 Olds Duel Gate Shifter
  168. 1968 w30 D heads and 7028254 carb
  169. Muncie side cover lever actuators
  170. Valve Cover To Air Cleaner Pipe
  171. Nos door weather strip
  172. Wanted 68ish to 72ish F85 horn button
  173. Sienna Seat Belts
  174. Upper Windshield Stainless Trim for '70 - '72 Convertible
  175. 455 TCS Solenoid Bracket Only
  176. WTD: 67 Cutlass Supreme rear bumper and brackets
  177. Cruise Control Servo for 83 H/O
  178. 1966 Cutlass Dash Harness
  179. Front coilover shocks
  180. '65 442 Side Scoops
  181. TH400 Inspection Cover 69 Cutlass
  182. Big block O4B
  183. 7027156 Quadrajet and Choke Coil
  184. Looking for GM 3.42 type O gearset
  185. 1966 F-85/Cutlass hood (whole or partial)
  186. 1968 442 Deck lid
  187. 1968 rear side marker lights.
  188. 66 442
  189. passenger tailight lens assembly 84 hurst olds
  190. Wanted for a 1959 Oldsmobile 88
  191. Wanted: Starter Brace & bolts for '73 88 455
  192. Looking for 1969 vista cruiser doors! Mainly passenger front door
  193. Roller cam thrust plate
  194. drive shaft
  195. 1936 F-36 engine rebuild parts
  196. 1100777 alt
  197. 56 olds odds and ends
  198. rear window molding
  199. Thermostat housing Number 5 casting 1970 455
  200. Glass Fuse Block 66-442
  201. 49 Oldsmobile Convertible
  202. Wanted-NOS front wheelwell moldings 230924/5
  203. WTB '72 Vista Cruiser 2nd seat seat belts
  204. WTB '70 - '72 OEM Washer Bottle
  205. GM Part# 3950197
  206. 1959-1964 Rochester 4GC 4 barrel carb
  207. In search of a crankshaft pulley rubber seal
  208. 73 74 75 Core Support
  209. Wanted: GM Olds type O 3.23:1 ring and pinion
  210. Tilt column
  211. Cruise control Servo Pontiac 79' 403
  212. NOS Mufflers 402618 and 402619
  213. 69 442 NOS Clutch Components Needed
  214. 1966 88 Parts
  215. 1966 Cutlass/442 wheel well trim to side molding fasteners/connectors
  216. Vinyl top molding 72 cutlass s
  217. 1966 442 Fenders
  218. 1968 Olds 98 vert rear bumper
  219. Toro/eldo western cyclone rims
  220. 1963 Starfire/88 rear seat anchors
  221. Help locating trim. ‘64 Dynamic 88 2 door
  222. 15x7 trm ring and snap om center cap
  223. Black 1970 442 manual transmission console
  224. Wanted 71 cutlass left sport mirror
  225. Wanted 1970 carb base
  226. 66 Toronado Rearview Mirror
  227. 1970/1972 - Looking for AM/FM Stereo Dial for 1971 Oldsmobile 442 Radio
  228. 1969 Cutlass S
  229. Need an Outlet Fitting for a 1953 brake master cylinder
  230. NOS '70 Inside Rearview Mirror 916904
  231. Complete AC Pulley Set: KK, KC, KH
  232. 1966-67 Toronado 88 98 gas pedal
  233. Need Pinion Yoke 8.2 P type Rear
  234. 1973 delta 88 front lower header panel l/ valance need
  235. 68/69 14x6 Unused SSII Gray Trunk Spare
  236. 1969 Cutlass/442 Convertible
  237. 1965 F85 dash board
  238. Front fender patch panels
  239. Wanted CF5 Astroroof Inside Cover/molding
  240. Wanted 1973 delta 88 front lower valance
  241. ISO 71-72 Cutlass driver side fender
  242. 1983/84 Hurst/Olds Wheels
  243. WTB headlight bezels for '75 Cutlass Supreme
  244. ISO 68 cutlass/ 442 holiday coupe Trunk lid & driver door.
  245. 1956 88 grill parts
  246. Trim for 72 A body bucket seat with power, black
  247. WTB Anti-Spin carrier for 8.2 BOP for 3.31:1 & up
  248. 1976-1977 Olds Cutlass 442 Grill
  249. Looking for a 5 main Halo.
  250. Defroster Duct - 66 442 Non A/C Car
