Kent Moore Type "O" Differential Rebuilding Tools
Old Dec 22, 2025 | 03:30 PM
69w30Olds's Avatar
Not sure if this is the correct place for this post since technically it's for tools, and not parts...However, I'm interested if anyone has complete Kent Moore tool kits to rebuild Type O differentials and is willing to sell the kit. Per the 1969 Service Manual, I'm looking for the following items:
J-22388 Pinion Seal Installer
J-8614-1 Holder
J-8001 Dial Indicator
J-21777-21, J-8619-12, J-8619-13 Pinion Depth Gauge Plate Kit
J-2235-1, J-2235-2, J22535-1 Pinion Holding Tool Components
J-21777-6 Dial Indicator Pin
J-21777-1 Gauge Shaft
J-8619-10 Gauge Disks
J-6133-A Pinion Bearing Installer
(Note: I already have the axle seal installer, which is why it's not listed)
I'm also looking for the differential housing bushing removal kit:
J-21474-3, J-21474-8, J-21474-16, J-21474-4, J-22545, J-21474-12, J-21474-8, J-21474-4
Lastly, Looking for the J-5395-01 rear seal (tail shaft) installer for M20/M21.
Thank you for any assistance you can provide - Rob
Old Feb 14, 2026 | 10:09 AM
nicks1966's Avatar
Are you still looking for these?
Old May 4, 2026 | 04:31 PM
klowery88's Avatar
I’d be interested in a J-5395 pinion seal installer if you have one.
Old May 5, 2026 | 09:17 AM
BackInTheGame's Avatar
I would have to double-check part numbers, but I'm sure I have nearly all that you need. I changed out my Diff a few years ago and used all the OEM Kent Moore tools I could find. Following the procedure in the manual, and using the correct tools Worked like a Champ. Had the clearances and backlash nailed down on the first try! If you still need anything reach out via PM.
Rich
Old May 5, 2026 | 07:24 PM
69w30Olds's Avatar
Hi Rich - I would be interested if you have the tools in my original listing. I'd like to do the same as you when I rebuild the rear end in my 69 W-30...use the exact same tools and following the service manual procedure. Please let me know what you have and are willing to sell.
Rob
Old May 6, 2026 | 09:57 AM
Rob, I'll check the list today and let you know. Once I rebuilt the rear end, I no longer need them.
Old May 6, 2026 | 10:37 AM
69w30Olds's Avatar
That would be great. Thank you!!
Roger60
Drivetrain/Differentials
Apr 19, 2018 05:24 PM
1965Jetstar
Jan 4, 2018 11:40 AM
oldsmobilty
Jun 25, 2017 06:28 AM
Peewee
Sep 25, 2011 10:51 AM
cluelesscutlass
Jul 25, 2011 08:34 AM
