Wiper switch
Old Oct 29, 2025 | 04:38 PM
Wilson's Avatar
Wiper switch
Can anybody tell me where I can find a 2 speed wiper switch for my 65 Cutlass? On-line the only one I can find is the 1 speed.
Thanks,
Wilson
Old Oct 30, 2025 | 06:52 AM
The original part number is 1993665. This switch was only used on 1964-65 F85s and Chevelles from what I can see in the parts books. There are no new ones available. Search that part number on Google as some N.O.S. switches show up occasionally.
Old Oct 30, 2025 | 09:48 AM
Maybe this will help:
1964 chevelle 2 speed wiper switch - Search Shopping
Old Oct 30, 2025 | 09:54 AM
Be careful. The 1964 Chevelle first design switch is not the same.
Old Oct 30, 2025 | 10:39 AM
Wilson's Avatar
Thank you!
Old Oct 31, 2025 | 01:21 PM
Wilson's Avatar
Can I just use a one speed switch until I find a two speed?
Old Nov 1, 2025 | 10:17 AM
Wilson's Avatar
Joe, I apologize in advance, it's been a while since I've used the forum and am not that familiar with how it works any more. I didn't know if you had seen my question about using a one speed switch in place of the two speed.
Old Nov 1, 2025 | 12:12 PM
Well, kind of, but it will only work on low speed. You need to ground the black wire in the switch connector and run the black/pink wire to the terminal on the single speed switch. This will give you low speed only. To get high speed you would need to disconnect the black wire from ground, but then you would need to reconnect it when you turn the wipers off to get them to park correctly. The correct two speed switch does all this internally.
Old Nov 2, 2025 | 02:46 AM
Wilson's Avatar
Thank you Joe!
pigfoot55
Oct 24, 2024 07:08 AM
Pug Wrangler
Jun 15, 2023 07:35 AM
vitaleyes
Nov 14, 2012 07:43 AM
delta881966
Aug 26, 2012 06:11 PM
