1966-67 Toronado 88 98 gas pedal
Old Aug 16, 2025 | 02:56 PM
BSiegPaint's Avatar
Looking for a nice replacement for my ‘67 Toronado pedal which disintegrated today. Let me know what you might have. I know several models and years used the same piece. Stainless trim is not needed if yours is missing it.
pic for reference
Old Aug 16, 2025 | 04:32 PM
deaddds's Avatar
As usual I should have a really nice one. Text me to look for one. Figure $40 for a good one. 618-554-4362
Old Aug 16, 2025 | 05:16 PM
BSiegPaint's Avatar
Sending you a text directly - thank you!
Old Aug 17, 2025 | 08:38 AM
cfair's Avatar
Unless I miss my guess, that pedal was used from at least 65-67 on 88’s, 98’s, Starfires and Toros.
If you get one with stainless, it’s easily removed as I’m guessing you know, but it can also be nicely shined up with a bit of #0000 steel wool per your preference.
The only functional thing to check is sometimes the rubber voids which pop over the ball can crack, but as long as at least one is sound, you’re in business. All the pedals do is pivot on them
Chris
Old Aug 17, 2025 | 09:36 AM
deaddds's Avatar
65 will work but it’s different. 66-67 are the same exc Cutlass
Old Aug 17, 2025 | 12:02 PM
BSiegPaint's Avatar
Chris
Thanks to deaddds for having what I needed! Appreciate the wisdo of 4-0 wool and elbow grease on the stainless. And yeah, you should have seen the rear rubber on my original explode all over the floor when the pedal bent backward (I was installing the mount after throttle cable work). It shattered like glass hit with a hammer. No saving that one.
dc2x4drvr
Apr 8, 2024 06:48 PM
70-455
Sep 16, 2022 12:12 PM
jaunty75
Jan 8, 2021 01:21 PM
ed burke
Apr 24, 2015 05:20 AM
Brad9876
Apr 9, 2007 01:14 PM
