In search of a crankshaft pulley rubber seal
Old Sep 1, 2025 | 08:26 AM
ElChavo1979's Avatar
Hi, I have a 1979 Oldsmobile Cutlass Calais Hurst/Olds W-30. It has a 350 V8 with AC. I'm in search for a crankshaft pulley rubber seal and pulleys.
Old Sep 2, 2025 | 06:48 AM
ROCKETMAN269V's Avatar
I'm assuming that you're referring to the harmonic balancer on the front of your crankshaft. They can be rebuilt or replaced as a unit. I have numerous used oem balancers, if you would be interested in a replacement. Thanks, Bob.
Old Sep 2, 2025 | 07:32 AM
Not exactly. The pulley is wobbly. I wish I can upload a video of what I'm talking about, but I can't. I also would like to see what a crankshaft pulley seal looks like so I can try and find it.
Old Sep 2, 2025 | 08:18 AM
The actual bottom pulley is bolted to the balancer hub, so if the pulley is wobbling, it's bent. There is no "crankshaft pulley seal" per se. The crankshaft front seal is easy enough to source; worse case, you would have to purchase a timing cover gasket set. Here is an image from NAPA.
Old Sep 3, 2025 | 05:19 AM
oldschool85's Avatar
pm sent
Old Sep 3, 2025 | 07:27 AM
is it possible to get a clearer picture please?
Old Sep 3, 2025 | 09:54 AM
Here you go
Top
Old Sep 3, 2025 | 10:33 AM
Top
OK. I just bought it.
Old Sep 4, 2025 | 03:02 PM
If anyone has a 3 groove, 4 bolt pulley, please let me know. I appreciate it.
Old Sep 5, 2025 | 05:29 AM
What is the number on the pulley? All Olds crank pulleys are 4-bolt; however, the diameter and offset very considerably. I have numerous pullies for crank, water pump, etc.
Old Sep 5, 2025 | 05:44 AM
Let me find out and I'll let you know.
Old Sep 5, 2025 | 01:44 PM
As noted, there is no "rubber seal". I would suggest that you take some photos and post them here so we can help you, since you don't appear to fully understand what you are looking at. It's hard to provide correct info with incomplete data.
Old Sep 6, 2025 | 01:26 PM
These are the measurements of the crankshaft pulley on my car.
Old Sep 7, 2025 | 08:26 AM
Unfortunately, it would take me hours to go through and measure all of my crank pulleys to find a match. Can you not read the # stamped into the pulley? Thanks, Bob.
Tropicalbill
Dec 4, 2016 08:09 AM
Martin555
Nov 12, 2016 07:40 PM
1950 Model Olds
Tech Editor's Desk
Jul 20, 2011 09:02 AM
Flye
Oct 12, 2009 06:47 PM
