- Cool video on piston rings and cylinder finish
- Main spacing from block to block?
- Double adjustable shocks for drag racing
- Halo girdle
- SpeedMaster Heads on sale
- vacuum pumps
- New NHRA stocker suspension ???
- 455 C Head Flow Test
- 64 cutlass drag strip times, 330 potential
- Hard Knocks
- Ontario Bracket Finals Rnd. #1
- 455 Oldsmobile Build
- Short or long?
- Hurst olds 260 mph
- southeast gasser super stock build
- Camshaft id
- E85 Gains - Volumetric Efficiency
- Who's going racing?
- robski's 64 F-85 needs a larger rad-need ideas
- (not mine) 57-64 Rear end Housing
- Pure Stock Drags 2020
- comp spintron
- Rare and forgotten Olds intake.
- Combined 1st Gear Ratio: 9.73 vs 10.68
- Electric Fuel Pumps - In Tank?
- New lobe tech from comp.
- .msd bronze gear
- Trovato 560 Rocket
- NHRA Camshaft Dwell Lobe Profile
- Main Girdle
- Interesting read sonic testing and metal strengthening
- One step closer
- Cylinder head flow testing article
- 455 two bolt main steal billet main caps ??
- Race bearings
- The 350 is still hanging in there.
- Chevy rods and pistons combination for small block stroker
- BBO vs SBO headers?
- Max Power with Ported Cs?
- DX based Stroker Cranks
- High Flow Air Filter
- World class dumb ass stupid screw up!!
- Escape Machine
- 1975 cutlass supreme headers
- NASCAR blocks
- March Performance 16045 install on a Batten Headed 455
- 1/4 Estimate and Trap Speed
- Rocker arm problem
- harmonic balancers
- G-body 455 headers.
- Air gap or Torker
- aftermarket pulleys
- Easy Horsepower, Water-Methanol Injection - N/A
- 455 intake manifold suggestions
- Cometic MLS for 455 with 1/2" head bolts?
- 331-391 gear change to camshaft update !!
- Recommended intake manifold gasket
- Water/Meth Kit for 455
- Oldsmobile exhaust manifolds, header type style !
- 1976 Cutlass Supreme 455 headers?
- 1970-72 Outside Air Induction Hood - K&N X-Stream Airflow Top Plate
- SCAT crank going out of production?
- Holy casting flash, Batman!
- Stock Crank Shaft
- 5A Iron vs Aluminum Performer RPM Cylinder Heads
- 57 tri power not mine
- Headers exhaust leak
- Point and laugh - R&R valve guides
- Unsprung weight reduction performance gain...
- Making 1000 hp N/A
- Building advice
- Dr. Dan's 478
- Safe limits of a DX block??
- Edelbrock Sale
- Payton Hunts New year Design
- Rhoads Lifters
- New Oldsmobile heads
- Headers and hp
- They don't make them like they used to, Thank God!
- ProComp vs C Castings
- Header question
- Girdle for factory 455 blocks
- finally back to drags
- 1987 442 Code 34 check engine light
- A liquid flow calculator
- Crank spacers
- Manifold height- ram air hood fitment
- Rocket racing block build street/strip build
- Stock 350 1/4 mile, past present future
- Finally update 331 to 391 1/4 mile
- Timing - I get it, but I don't understand it
- New Street Demon teardown
- Timing curve.
- Crankcase ventilation on high-perf engines
- Jumble of parts... some direction please
- Pushrod length
- New personal best with the new 355
- Assault Aluminum Rockers
- Olds 350 10.5:1 HEI Spark Plugs
- best engine Recipe for high power levels
- Need Starter Guidance
- oldsmobile 1968 350
- Olds Engine builders engines for sale
- Dave Smith cam
- Bop rcae great lakes dragaway
- Cnc porting
- Need Header Guidance
- 350 block limits?
- Ring Tech
- Need Input-Cam Selection
- Question about electric choke adjustment..
- Need Input- 1/4 Mile & Trap Speed
- 3.73 to 4.10 Gears in 1972 442
- Sealed power/ Harland Sharp Rockers
- Hyd. Roller in DX block
- Recommendation
- 1972 NHRA Stock Oldsmobile Dyno Test
- update from the 331 to 391 pics are on first post !
- Milling heads
- 350 rocket performance suggestions
- 2020 oca nationals race
- MSD Atomic EFI Throttle Body Injection
- Comp cam roller rockers pushrod length?
- Can you tell what brand these are
- rear axle change 331 to 391
- 455 block prep and bearing clearance for street supercharger
- Large intake valve small bore ???
- 1966 tri carb
- aluminum heads
- Oldsmobile offshore aftermarket rods ???
- More New Products
- New G block build
- 455 valve spring issues. Help
- Dual Quad Intake BB Olds
- Eaton brand 8.2 posi unit # 19674-010 NEW!!!
- J heads... dead horse!
- Edelbrock total power package or just heads
- Need advice on parts
- Serpenti belt set up
- headers
- Early 400 vs 455
- Making good 3 piece performance pushrods into oil restricted ones
- Rocket Racing crank
- Question for the masses...
- Quick fuel technology 850 double pumper
- Why do alum. heads .........?
- CP vs DSS pistons
- Exhaust system question...
- FI tech fuel injection
- 1969 70 distributors for 455 olds
- Looking for reasonably priced headers...
- Look At What I Came Across Today
- Nationals Race Night
- 400 flywheel
- Anyone know who makes these?
- torque storm supercharger? Dyno numbers?
- Fuel for racing!
- 65 442 with 425 slow ??
- Upgrading a Batten Headed 455 originally built by Joe Mondello 20+ years ago
- Front End Weight for Springs
- Holley sniper EFI issues
- New Aluninum Heads, high lift cam, motor turns slow
- distributor 455 advice !
- twin gt45 455 build need advice
- MSd Olds Plug n Play no limiter?
- Went bracket racing last weekend
- Pretty cool.
- Eagle H beam rod block interferance?
- Offenhauser Intake
- Jm 25/28h
- Setting Poly Locks on Roller Rockers?
- Porting my j heads
- Optimizing timing curve
- Time to see what Lackluster performance equals in the 1/8 mile
- Ignition opinions
- What are your feelings on header wrap?
- How does a cast iron (non nodular) crankshaft fail
- 403 Street Build looking for feedback
- building a torque plate
- New to me!
- Oil restrictors?
- Thoughts on these headers?
- Heat riser block off epoxy & plugs together???
- Heat cross over filler
- CVF Serpentine System
- Header Removal ?
- Olds 455 Dyno Results
- Thornton Tubular Exhaust Manifolds
- Air/Fuel Ratio Oxygen Sensor Targets?
- Serpentine System Wanted
- 455 build ???
- 1970 455 1966 L69 mock up
- Main Cap Question
- 372ci build in progress
- 1969 H/O PCV Dual set up ??
- How many ponies will I gain ?
- Final gear nitrous ?
- The best tuning tool for suspension.
- Main Cap Stud Question
- 3/8 fuel lines and fuel pump
- 350 Olds Build Questions
- Factory cast iron intake manifolds
- What would you like to see in a CDI ignition system?
- Bracket Issues after Aluminum Head Swap, Olds 455 Please Help!
- 1966 Cutlass convertible blown 330 project....
- Stock windowed 350 olds takes tons of nitrous
- Engine running at higher rpm after hard driving
- 66 olds 425 98
- Small block feedback
- 1974 Omega 455 carb options
- Torque Converter Efficiency
- clutch package
- Big cam and A/C
- 2 piece timing cover
- 324(was 303) with #18 heads question
- Ross racing engine
- Billet heads
- New Block
- Race car insurance
- Standard manifold to RPM
- Headers
- ROCKY ROLLERS any body know what these are?? THANKS
- no baffles, valve covers
- Engine code question
- Engine plates/ mounts
- Mondello Knowlton heads
- 350 vs 455
- March Style track surpintine belt system
- Seriously? Cams again?...yep
- Is edelbrock performer olds 455 a good intake
- Spring seats on Edelbrock heads
- Lexan for 1970 cutlass
- Rocker pivots
- Harland Sharp S4003 Ford Rockers
- Headers for a G-Body
- Porting and enlargin valves, cast iron heads
- Best place to mount a 6AL box?
- Headers
- Valve covers
- Magic Carpet Ride 1972 Cutlass drag car
- Screw in studs with factory heads
- Who has a full chassis car?
- What heads are these?
- 394 engine ohaul
- Annealing parts
- Looking for proven build sheet
- spark plugs
- Anyone know what conversion U joint is needed for a TH400 to a stock 7.5" G body driv
- Swapping from Olds 350/2004R to 455/TH400 long tail?
