Air/Fuel Ratio Oxygen Sensor Targets?
Old Jan 14, 2018 | 08:05 PM
cfair's Avatar
I just installed O2 sensors in the exhaust systems of 2 carbureted 455’s.
Both engines are mild builds, 800 cfm Qjets, with HEI, and factory duals. In big street cars, a ‘66 98 and a ‘66 Starfire.
In CA, our gas is about 10% ethanol, which I gather means I should aim at a stochiometric ratio of 14.1:1 or so instead of 14.7:1 as you would for pure gasoline. I suspect that %’age of alcohol means richer across the operating range.
I can dial in the idle to 14.1 no problem, but what are the air/fuel ratio goals I should aim at for part throttle cruise, acceleration, and WOT?
Opinions?
I understand qjets well, but I’m new to this information as inputs to tuning them.
Thanks in advance for any guidance
cf
Old Jan 15, 2018 | 04:40 AM
cutlassefi's Avatar
I can dial in the idle to 14.1 no problem, but what are the air/fuel ratio goals I should aim at for part throttle cruise 14.5 or so, acceleration 12.5-12.8, and WOT Same 12.5-12.8?
Opinions?
cf
It'll also depend on the amount of camshaft in it but hope this helps.
Old Jan 15, 2018 | 05:04 AM
jensenracing77's Avatar
I can't help on this but do have a question on the subject. I have been interested in this for a while but not studied up on it yet. Do you have a recommendation on what kit to use or any information about doing this?
Old Jan 15, 2018 | 05:43 AM
cutlassefi's Avatar
I use and sell the AEM stuff, because imo it's the best stuff out there, especially for the money.
Old Jan 15, 2018 | 06:17 AM
Don't mean to steal the thread, maybe I should ask in another one... With the Jetfire models we are flying a little blind. They have a single bbl side draft carb and turbo setup. Most of them run lean with no jets or needles available. I have played with our automatic car by drilling the jet and also playing with the needle. I have it running nice but I am sure it is to rich now as I am sooting up the turbo turbine. Would it be worth the money to aid in this or is there a better way? The plug readings are all over the place with the water injected. At least they are not like I am use to seeing with ATV race engines.
Old Jan 15, 2018 | 09:16 AM
cutlassefi's Avatar
Buy the Wideband, you can use it on just about anything.
Old Jan 23, 2018 | 02:23 PM
74sprint's Avatar
I use O2 wide bands from 14point7.com they are cheaper and top quality. In today's day and age I wouldn't tune a car with out one.
Ray
Old Jan 23, 2018 | 02:45 PM
1970greensupreme's Avatar
14 to 1 is good, even pushing 14.7 at idle, cruise. Moderate load, 13-1, WOT 12.5 to 12. E85 is crazy, like 8-1 but good for boost and high compression. Timing, cam, compression will play a factor but I assume you know that
Old Jan 23, 2018 | 02:47 PM
I agree, for around $200 you can't beat it. Back when I was in the tuning testing biz in the early 90's through 99 a wide band afr monitor was near 15K
Old Jan 24, 2018 | 04:52 PM
cutlassefi's Avatar
Ray
Just went to that website. First thing they mention is value, not accuracy. Hmmmm
oldsygoody
Jul 20, 2014 09:36 AM
blleach
May 8, 2012 08:33 PM
gtonut57
Aurora
Sep 27, 2010 11:15 AM
84oldsDelta88
Jun 24, 2009 03:40 PM
cormike
Aurora
Jan 4, 2009 07:30 AM
