Fuel level sensor? HELP!
Old May 8, 2012 | 07:35 PM
blleach's Avatar
A wise man once said the only dumb question is one not asked so, here I go with a question that some of you might consider dumb. Lol. Is there some sort of fuel level sensor on the 1970 Cutlass Supreme? My cars gauge will say it has a half tank and then it runs out of gas and it is way over the full mark when filled up. The gauge itself doesn't seem out of place so I don't think that is the problem. A sticky float in the tank wouldnt make the dash dial overshoot the "full" mark so I'm lost from there. I'm looking for some pointers on how to fix this. Thanks!
Old May 8, 2012 | 08:11 PM
Your sender (or sender wire) has too much resistance - it may need to be replaced, but you may get away with just cleaning up the rheostat windings and wiper.
See posts here and here for a little bit more information.
Old May 8, 2012 | 08:33 PM
blleach's Avatar
Awesome! I will be definitely be fixing the problem. I'll be sure to update you on the fix. Thanks a bunch!
oldsygoody
Jul 20, 2014 09:36 AM
louie
Apr 11, 2011 06:07 AM
poorboy_616
Jul 4, 2009 05:16 PM
asadebo
Alero
May 3, 2009 08:35 PM
The_Jeremiah
May 2, 2008 05:22 PM
