bosch or ACdelco oxygen sensors for a 84 delta 88 need help
Old Jun 12, 2009 | 07:23 PM
84oldsDelta88's Avatar
about 2000-5000 miles ago i replaced my oxygen sensor with a cheap bosch universal type. and now its already dead. im wondering should i go and buy the oem bosch oxygen sensor or a oem ACdelco oxygen sensor. the acdelco is 30 dollars and the bosch is 20 im wondering is there a difference in quality and lifespan? im running a 307 oldsmobile v8 small block by the way. and i have a air/fuel mixture gauge and after the car drives for a couple of minutes the lights disappear on my gauge. could something else cause the oxygen sensor to die premature or is it just bosch sucks?
Old Jun 20, 2009 | 06:25 AM
Texascarnut's Avatar
Geezer
Check your EGR valve for proper function.
Old Jun 20, 2009 | 08:47 AM
Joeypete's Avatar
I installed a Bosch sensor a while back on my Toronado with the 307. It really improved the performance...so far so good. That was the only brand I could get locally so I figured I'd try.
Old Jun 21, 2009 | 06:07 AM
Lady72nRob71's Avatar
From all of the issues I have personally heard of in the past regarding the Bosch, I would stick with AC Delco. Given how long they should last, 10 bucks more is not too much.
Old Jun 24, 2009 | 03:40 PM
thank you all for your answers it wasnt the egr i found out that the oxygen sensor i had bought had a warrenty so the store gave me a brand new oem bosch oxygen sensor and so far so good no check engine light and my fuel/air mixture is back online so hopefully this one holds up or next ill buy the acdelco
chasman414
Oct 30, 2014 03:15 PM
Tony72Cutlass'S'
May 20, 2013 07:29 PM
BILL DEMMER
Nov 10, 2012 09:59 PM
gtonut57
Aurora
Sep 27, 2010 11:15 AM
