Halo girdle
Halo girdle
Good evening, I’m looking for who makes a 5 main halo these days. I always saw j and s but he retired? I’m just looking for a little more strength for a big block I’m piecing together.Any help will be great!
Mark would you mind expanding on your 5 main Halo
How is it manufactured?
Metal grade ?
Thickness ?
Bolt quality?
Fit & Finish ?
Country of origin ?
General understanding is that Jim L. retired, moved to Florida and sold the girdle business to this person. Click on the link below:
https://www.jsmachineolds.com/
Flatness will be guaranteed at .002 or less. Jim’s weren’t ever even close to that.
Material is yet to be determined but it will be at least as strong as Jim’s were.
Sounds like a nice piece so far.
How accurate will the hole location be as in how tight will the Halo fit around the studs?
I wasn't to fond of milling caps 1 thru 4 to meet the rear main. So I used some custom ARP studs and washers at the rear main so that I could bolt down the Halo without milling caps 1 thru 4. This also helped the Eagle stroker crank clear the Halo. Oil pump and pan fit perfectly.
Similar to pic below:
In my application I used a stud with a fixed nut above cap. The pic was not of mine. I used it for the gist of it as I did not take any pics of my actual set up.
As for whether or not it helps... well that's a little controversial. I believe it does and at least it can't hurt.
I got a question, what part number studs do you guys use for the larger 1/2" studs with a girdle? I used the 1/2" longer Ford 302 stud set with a girdle. Great for 1 through 4 on the 403. The 351W is 1/2" but ARP doesn't make a set for a girdle. If I go with a 5 main Halo, what studs work with #5? Does it have to be a ARP custom order?
Is it a 5 main? I picked up a nice 1/2"+ 4 main CNC Halo for a good price. It sounds like a 5 main is worth picking up, just need to figure out what stud is used for bigger 1/2" stud rear main cap on a 403 with a 1/2" thick Halo.
It's a 5. If you do get one, knock the paint off before installation, otherwise it will flake into the oil.
The funny thing about the halo is the difficulty in proving its effectiveness. The engine was built with it, so what do you compare it to?
Jim’s plates weren’t really indexed well. They fit better over some of the mains than others. Plus if you look closely the hole were tapered upward, not sure why he did that.
When these blocks break its normally between the caps and pan rail. So, a properly engineered 5 main halo should offer some rigidity in that area.
However I can tell you from experience that you’ll get reduced bearing wear and overall longer life if you do two things, reduce reciprocating and rotating weight, and internally balance the cranks, even small blocks.
We’re doing things with these blocks that they were never designed to do. You have to help them out wherever possible, especially as power levels increase.
Are you concerned with the shear load on the main stud ?
Had machinist check and all is dead even across 1 thru 5.
I don't understand why others think this is a poor idea !?
I've seen this in other non Olds applications.
It clears my crank, oil pump and pan is good.
I don't see why I have to mill caps 1 thru 4 for this to have the effect I'm looking for . Hmmm ..
I'm not a master engine builder or an engineer. But I'm gonna give it a try.
I have to wonder what today's engines would be if they stopped trying new things.
Thanks again for sharing your idea !
#31
Nothing is torqued down. Nuts are on loosely.
if when I torque down mock up and I feel I do not have enough thread I will change them out for longer ones.
Thanks for heads up !
Remember... Some of Mankind's greatest discoveries were made by thinking out side the box.
#33
#34
#35
#36
#39
VORTECPRO what are your thoughts on the Halo for mild HP builds? Also on installing the Halo without cap milling 1 to 4 and shiming the number 5 main using the nut and shims if necessary?
Bernhard
Bernhard
The last 455s I've built I took so much weight out of the bottom ends it probably is a lot easier on the block. When you take a crazy about of weight out of the balancer and flex plate its not far from internal balance.
I'm no Olds expert and don't claim to be but, I've seen several 10 sec full weight Olds without girdles never hurt a block or a bearing, but maybe when you start making real power it can become a problem. I know the Buick @ 600 HP and 7000 RPM is a problem. If I had to run a girdle on a Olds the block would be filled.
#40
Really we should be looking at how Chads block is done I assume its a production Olds block, for a car to run the MPH it does you have to turn over 7300-7500 RPM in the lights, which he's done consistently.
