vacuum pumps
Old Nov 26, 2020 | 12:57 PM
wills30's Avatar
vacuum pumps
i have a 800 hp. motor. and i need to install something to get rid of the pressure in my crank case.
so I'm looking into get a vacuum pump, what are you guys using. is their any kits that would solve all the parts needed.
without mix matching parts, and benefit more than taking hp and torque away .i see gz , star and mororso say their product is the best, prices ranges are kind of crazy. so what would be the beat bang for the money .and help me from suck my oil pan gasket into the motor, willie
Old Nov 26, 2020 | 01:00 PM
redoldsman's Avatar
Proud Viet Nam Veteran
Interesting. I have never heard of anybody doing this.
Old Nov 26, 2020 | 01:43 PM
VORTECPRO's Avatar
Star racing pumps are top notch, the only pump we use.
Old Nov 26, 2020 | 01:50 PM
wills30's Avatar
I've call them once.
Which pump would benefit me the most.
Sportsman / standard/ mountain. I see a kit for standard and sportsman.
How much more machining to get them to fit.
Old Nov 26, 2020 | 01:52 PM
wills30's Avatar
I see the gz's are the cheapest .
and state they out pump the other's??
Old Nov 26, 2020 | 01:55 PM
VORTECPRO's Avatar
Heres my setup above. Fabrication is involved.
Been common on high output race motors for decades. You'll find some background info in this article.
Old Nov 26, 2020 | 02:01 PM
wills30's Avatar
looks like the sportsman
What kinda hp and torque range are you making.
Old Nov 26, 2020 | 02:07 PM
wills30's Avatar
i read that and went to his website
Old Nov 26, 2020 | 02:29 PM
VORTECPRO's Avatar
505 makes 947 HP @ 7600 RPM 720 TQ
Old Nov 26, 2020 | 03:20 PM
wills30's Avatar
which pump are you using
Old Nov 26, 2020 | 04:06 PM
VORTECPRO's Avatar
Part No: STR.03.01.000
Old Nov 26, 2020 | 04:40 PM
chadman's Avatar
I have the Star Machine standard pump, drive mandrel and oil separator can on mine.
Old Nov 26, 2020 | 04:45 PM
wills30's Avatar
did you buy the kit or did you have to buy each parts.
And if you did buy the kit .
What other parts did have to buy to complete your set up.
By the way yours look awesome.
Old Feb 25, 2022 | 04:18 PM
wills30's Avatar
Where is a good place to hook a vaccum Guage.
to determine how much vaccum I'm pulling.
Valve cover or fuel block off?
Old Feb 25, 2022 | 04:29 PM
If you're asking about the vacuum pump performance, I would assume any crankcase fitting would work. They should all be at approximately the same vacuum level. To avoid any latency issues in the valve covers, the fuel pump block off is probably a more repeatable location.
Old Feb 25, 2022 | 08:28 PM
wr1970's Avatar
I agree top notch stuff.
Old Feb 26, 2022 | 06:46 AM
wills30's Avatar
fuel block off plate is the simplest. But was hoping to hear from others with aftermarket vacuum.
377rick
Jun 6, 2019 07:07 AM
Mymerryoldsmobile
Apr 24, 2016 07:32 PM
quentinnw2
Oct 25, 2013 09:26 AM
Rocket331
Mar 10, 2013 10:32 PM
zodiacblueS
Brakes/Hydraulic Systems
Oct 4, 2012 06:22 AM
