southeast gasser super stock build
Old Oct 8, 2020 | 07:48 AM
Daniel828's Avatar
Im looking for some direction about my engine build for Sega super stock class. They only run 1/8 mile tracks and the quick stock class guys are prob in the low 7s The class break down is 8.5 x cubic inch for big blocks and 9.5 x cubic inch for small blocks and they have to be 4 speed manual and have to run a dual plane intake.
I have a 66 4 door cutlas that weighs 3770 currently with a 455 and th350. I have a spare stock 455 block, crank and rods with 30 over speedpro pistons and spare E heads with big valves that have a mild port and bowl clean up. If I stick with 455 ill have to add weight to get to 3920 lbs. So Im thinking maybe I should build a 350 and shave some weight down to 3400 lbs but Id have to look for a 350
My thinking is to go with the less weight route with deep gears 4.56 or lower to get the weight moving but im not sure and im open to any suggestions.
thank you
dan
Old Oct 8, 2020 | 10:57 AM
wr1970's Avatar
thank you
dan
if you are going 350 I would do the 350D/350dx you could make a cheap dependable engine with a 330 crank stroked to 3.50 and bore it . You could use and 425 crank it you have it cut down on counter weights and stroked to 4.0 Now the better plan is get a crank that Cutlassefi Mark has drop in 4.00 in a 350D/350dx and bore it . No girdle required with the 350D/350dx. Jmo
young olds
Apr 26, 2017 11:40 AM
oldstata
Feb 20, 2014 06:19 AM
docjackson225
Jun 15, 2013 05:05 PM
RandyS
Feb 6, 2013 01:24 PM
Bernhard
Nov 22, 2012 07:12 PM
