PDA
View Full Version : Racing and High Performance
Pages : 1 2 3 [4] 5 6
  1. Ping and no power rebuilt 455, aluminum heads and intake from mondello
  2. Headers 442
  3. Low Cost Stainless Headers from eBay
  4. Turbo vs supercharger
  5. Modification questions
  6. Rocket Vapor
  7. Suspension Question: Will this setup work well?
  8. supercharged 455
  9. Distributor Hold Down Clamp Heavy Duty????
  10. Old'en Days Drag Racing Lots of Olds
  11. Header choice - '70 442 - hooker super comp 1 3/4 ?
  12. traction problems
  13. Edelbrock heads - later version much better than earlier?
  14. New best in the wagon
  15. 1972 delta 88 2d street strip car
  16. Engine Shop in Bay Area
  17. EMC Questions
  18. Going racing
  19. non SFI trans
  20. turbodsbo
  21. Can't decide
  22. shift light and tach not working right
  23. High 11's
  24. Low 12's what does it take
  25. 2016 drag race competitors
  26. Opinions on my spark plugs?
  27. rear springs
  28. MSD help
  29. Well this would be fun.....
  30. Choosing/designing a 350 street cam?
  31. first time taking the 66 to the track
  32. milling heads
  33. Not so impressive track run
  34. Header test by cutlassefi
  35. QA1 suspension kit...???
  36. 2.5" exhausts
  37. Grill tape in 1950s NASCAR
  38. 2016 Buick Olds Cadillac Nats
  39. factory installed traction bars
  40. I want to build a street 403 with a turbocharger..low boost
  41. New PB 11.37 @ 119.37 mph @ 3800'
  42. Great lakes dragaway BOP days 2016
  43. New PB
  44. HEI Rebuild and Recurve
  45. Quadrajet Issues...
  46. Wheel Hop
  47. Anybody using PRW 0230201 Stainless Rockers?
  48. NOS tunes / results
  49. Thinking about going fuel injected
  50. 1987 442 Ready to race
  51. Header bolt issues
  52. 350 heads and carb
  53. Factory diff on a 55
  54. Back together, new PB
  55. Mild performance/ high?
  56. Looking to build a hot street 403
  57. 4 Bolt main 455 race block
  58. Rear Axle upgrade ??
  59. Best slick size for E.T
  60. whats the limit for a sbo (gas block)
  61. We need a section for supercharging and turboing
  62. wheel hop
  63. Iron Head porter
  64. 73 cutlass Exhaust
  65. headers 72
  66. In need of flattop 403 pistons
  67. Twin turbo HELP!! 66 442
  68. which headers???
  69. Fuel System Upgrade
  70. 455 overbore limits
  71. Scat crank billet new offering
  72. 455 crank in a D/DX block
  73. 950 carb
  74. Why didn't Olds use a 7" rod in a 455
  75. Winter racing builds for next year
  76. Pro comp heads on a race engine
  77. olds racing block
  78. DX Build Recipe?
  79. Current options for bore and stroke in a gas 350 block
  80. headers for a 1965 starfire?
  81. crank weights
  82. RareSX
  83. 1/4 mile unsatisfactory GLD.
  84. My last weekend racing ( i think )
  85. Wayne and Aaron Shipley
  86. Wagon debut at track today
  87. Milan's 795 HP Beast
  88. winter shift
  89. BYRON DRAGWAY B.O.P race
  90. We made it happen today.
  91. 442 stock 455 cam specs for an auto car 0.050
  92. DX block sonic check results
  93. 62 Starfire
  94. Valve spring choices
  95. Spark Plug Color
  96. Considering EFI
  97. How to Shave 3 Tenths off Your ET
  98. Data logs
  99. Racing Calculator Thread
  100. Finally hit the track
  101. 461 Caprice
  102. Hood scoops
  103. Quadrajet verses Holley 850 double pumper
  104. NHRA Sonoma
  105. Drag racing engines for Oldsmobiles
  106. Dick Millers Olds Powered Nationals Norwalk Ohio
  107. First time at the track - ever!
  108. Algon Injected 455!
  109. Oldsmobile 455
  110. Intakes
  111. High Performance pistons
  112. Racing engine build thread
  113. Not quite sure where to put this..
  114. Cam specs / degreeing
  115. Help getting engine tuned up for optimum performance
  116. The go faster thread
  117. Classic Olds ET List (Historical Runs)
  118. Norwalk
  119. 455 roller cam
  120. Turbocharged Small Block
  121. Runner Up Pro Class
  122. stroker olds
  123. piston rings
  124. Classic Olds Racing Full Throttle List (Reference)
  125. Aurora 4.0 in performance RWD application?
  126. builds
  127. MY Junk Test
  128. The DRCE Engine and other topics.
  129. NHRA competition classes
  130. Small block heads vs big block on 403
  131. best head porter. edelbrock,procomp
  132. 2015 OCA Nationals race
  133. New X-43 4 Valve Racing Head
  134. installing motor plates, what water pump would you use?
  135. 66' 425 starfire into a 79' firebird
  136. a couple of porting questions
  137. Speedmaster Valve Springs???
  138. NHRA Fuel Tank Rules
  139. Mark Smith
  140. 1979 cutlass info
  141. The 307's last 1/4 mile run, and a new record
  142. Olds racing gears
  143. Oldsmobile Race/Show Nationals
  144. Oddessy batterys
  145. Ultimate Street Car Assoc.
  146. Bigs and littles wheel tire combo
  147. Best mufflers for a stock olds 350
  148. Evac systems
  149. stock oldsmobile rev limit
  150. Exhaust Cutouts = Power Loss?
  151. 12 second 350 olds cutlass magazine article
  152. Is this what people are using for the....
  153. Fuel vapor return line
  154. OL4B intake question
  155. Need help selling a 85 Iroc Z race car
  156. Fast E.F.I system
  157. New to oldsmobile performance
  158. Electric Fuel Pump?
  159. Batten Head production numbers.
  160. How much torque/lb-ft with rigth gearings to make wheelie?
  161. Milling small block heads
  162. 6 to 8pt cage
  163. Bore & Stroke for my 470 & 524 strokers
  164. Chrysler 8.75" pros and cons
  165. Cylinder Head Question
  166. Has anyone here ever twincharged a cutlass 350??
  167. Post your 11/12 second 455 combos!
  168. Holley Fuel Mat
  169. Going to do it...EFI for the 442
  170. Carb question?
  171. Carb for this
  172. any info on this fi setup?
  173. Roller Cam Bronze Distributor Gear Issues
  174. help choosing a transmission
  175. Spools on the street
  176. post to cut out thread from real olds power.
  177. Solid vs poly motor mounts
  178. Solid or hydraulic roller?
  179. HYD Roller Lifters
  180. First time nitrous install and use
  181. ARH Headers Installed 2 inch 3 1/2 collector
  182. NASCAR heads
  183. 4A junk heads - what to do?
  184. Need cam selection help for a 455......
  185. Bosch Platinum spark plugs
  186. Dick Miller DMR-68 headers
  187. Valve to Throat Ratio - Edelbrock Heads
  188. hot rodding noob!!
  189. looking for turbo info 425--455???
  190. Elec fuel pump/reg
  191. What are slicks?
  192. Timing/Distributor recurve
  193. Cam install ?
  194. New Personal Best into the 10.8s
  195. 72 cutlass stock eliminator
  196. Who has had this happen while breaking in a cam?
  197. NASCAR block years cast
  198. Old vs. New
  199. The Batten controversy!
  200. 1982 3.8
  201. Byron BOP Flyer
  202. 70 350 are they a free wheeling engin
  203. Big block heads on a small block headers
  204. 350 Rocket
  205. Edelbrock, Holley, or Quadrajet?
  206. Electric Fuel Pump GPH Flow Question
  207. 68-72 Cutlass Mini Tubs
  208. 2015 Dick Miller Oldsmobile Nationals is on
  209. Wheres the pics from Norwalk
  210. putting a groove on crank
  211. 455 build questions
  212. While ya'll were having fun.........
  213. timing chain alingment question
  214. Ohio weather forecast
  215. Dick Miller Oldsmobile Nationals
  216. OILS and Lubes
  217. Cloyes 9X Timing Set
  218. Spark Plug Recommendation #5 355
  219. the camshaft blues
  220. Scat 2-500-7000-990 H Beam Connecting Rods Stroker For Sale
  221. Horsepower/Torque Questions
  222. 2014 OCA Nationals Race
  223. Engine Builders?
  224. Msd al6-2 programmable box
  225. 472 to a 455 help please!!
  226. rocker arm and studs
  227. 74 fresh/350 mix match heads #3 & #6 HELP!!!!
  228. No oil pressure
  229. Fuel pressure regulator
  230. Drag Tests 60-70's
  231. This is a steal!!!
  232. Olds type "O" rear end gears
  233. Turbo for olds 350
  234. Street Car Race
  235. Sanderson Headers??
  236. Need some 394 flywheel help!
  237. Auto Trans Neutral Lockout Mod
  238. boxing a frame.
  239. 455 J Heads can i make them work?
  240. whats the going rate for a diesel block?
  241. Help on opening up oil drain back holes in heads
  242. New RR/Wenzler Headed / BTR 468
  243. Now we are the fast guys....
  244. Uh oh! RobbMc fuel pump with passenger side alternator?
  245. Electric Cooling Fans
  246. small block or big block?
  247. 73 Cutlass Header help
  248. 1/2 Line, Regulator, and Electric Pump Install
  249. Headers for 1972 Cutlass Supreme
  250. WPE EFI (spy shot)
