472 to a 455 help please!!
Old Jun 15, 2014 | 04:12 PM
Wgeir1979's Avatar
Unhappy 472 to a 455 help please!!
We recently bought a 72 cutlass and it's currently set up for drag racing it's got a 455 in it that's supped up to a 472 it's too much power ( lol) for what we want to do with it my question is what would it take to take it back down to stock? I'm not an engine guy I can do the work myself if I just knew what would need to be done. Thanks for the help guys.
Old Jun 15, 2014 | 04:30 PM
mrolds69's Avatar
Oh...too much power? I hate that! I don't know, you can't really make a bigger engine smaller. We would need to know what's been done to it. You could put a stock intake and carb on it, if it's got fancy heads you can swap them back. You can change the camshaft closer to stock. The size of the engine is probably not really the prob, it's the way it behaves. Someone here might even swap you for a good stock motor.
Old Jun 15, 2014 | 04:34 PM
Most complain that there is not enough power... The 472 is cubic inches and means it has had machine work done to it. The internals determine what kind of power it will put out. Do you know what parts have been installed inside the engine, stroke, pistons, and cam. Do you know what the compression is? This info will help determine a direction to take.
Old Jun 24, 2014 | 07:43 PM
PL ENDO's Avatar
i might trade you for my mild build 455. its only putting out 312RWHP and 384RWTQ
Old Jun 24, 2014 | 09:33 PM
70cutty's Avatar
Beer Connoisseur
probably start with changing rear end gears, tc and cam. that will mellow it out.
Old Jun 25, 2014 | 04:01 AM
Remember, as with increasing performance, if you want to reduce performance, you need to do it as a package, not one part at a time, so that everything works together, and it has enough power in the right places.
Maybe it'd be easier to just put a stop under the gas pedal, or increase the radius of the lever that the throttle cable pulls on at the carburetor.
Welcome to ClassicOlds.
Old Jun 25, 2014 | 09:59 AM
rubeng442's Avatar
Find out what you have first. The size of the engine won't change. But if you know your compression ratio, cam, torque converter stall and rear gear you can determine how radical the combo is. But if its a street car, the only thing you should need to tame it is the accelerator pedal.
Old Jun 25, 2014 | 10:09 AM
The other thing I would say, along the lines of one suggestion above, is that if you find someone who would like to swap their less-powerful engine for yours, you both have the advantage that you can drive the other car first to see if you like it.
That being said, in such a situation, you could always just swap cars.
aquabird
Oct 2, 2013 10:34 PM
67cutlass67GS
Non-Olds Engines
40
Jun 22, 2012 12:56 AM
dan2286
Jul 25, 2008 10:43 PM
472 big block olds
Jan 4, 2008 03:12 PM
drtdobber
Feb 14, 2007 01:16 PM
