Fuel vapor return line
Old February 19th, 2015, 09:55 AM
acavagnaro's Avatar
I have an aftermarket mechanical fuel pump installed on my '69 400G. The engine is relatively lightly modified (aluminum heads/intake, Demon 750cfm carb) and runs fine. When I installed the fuel pump, the manufacturer recommended I not hook up the vapor return line. His theory was that this could possibly starve the engine of fuel under hard accel conditions. I followed his advice and the engine has been running fine under light acceleration conditions.
About 2 weeks ago I got on it from a start (~75% throttle) and the engine started running a little rough and finally stalled once I slowed down.
My question is what symptoms might I expect to see by not having the vapor return line connected. Any comments are appreciated.
acavagnaro is offline
Old February 19th, 2015, 11:58 AM
wr1970's Avatar
What brand of pump? Are you running a fuel pressure gage?
wr1970 is offline
Old February 19th, 2015, 03:34 PM
therobski's Avatar
I have the same problem, however I'm running a Holley 125 electric pump and same thing, under a hard run the motor starves-bogs until you get out of the throttle. What are you using for a vent system? 67-455 retro-mod 442, the robski
therobski is offline
Old February 19th, 2015, 03:36 PM
therobski's Avatar
FYI-also I have a RobMac 1/2 inch pickup in the tank.
Old February 20th, 2015, 09:22 AM
acavagnaro's Avatar
Not sure of the specs on the pump but I could get them. It's a mechanical pump in the stock location running a 3/8" feed line. I installed an Earl's in-line filter about 4" upstream of the pump (low pressure side). My engine builder tried to convince me of leaving off a filter to avoid potential starvation problems but I don't like that idea. I could easily remove the filter to see if that makes any difference but I don't really want to run it without a filter. I'm not sure if installing the filter on the high pressure side would make any difference.
As far as a vent is concerned, I have the factory vent at the tank but nothing else. That's what got me wondering about the need for a return line. It would be easy enough to install one and try it but I figured I'd ask to see if anyone else tried running without one and if it caused any problems.
Old February 20th, 2015, 09:37 AM
wr1970's Avatar
Ding ding the builder is right!
wr1970 is offline
Old February 20th, 2015, 09:42 AM
oddball's Avatar
A vapor line is to deal with vapor lock, which is normally when trying to hot-start the engine, not while running.
A filter on the suction side of the pump is a bad idea and can make the pump starve. Move the filter to the pressure side.
Bear in mind the carb bowls can run the car even at WOT for a few seconds. So if it bogs immediately then it's definitely a carb issue. In any case, I still expect it's a carb issue.
oddball is offline
Old March 5th, 2015, 09:56 AM
acavagnaro's Avatar
Just a quick note to wrap this up. I tracked the source of the problem to a weak connection for the 12V HEI power source so it wasn't fuel related at all. However, I did take the advice given above and have moved the fuel filter from the low pressure side of the pump to the high pressure side.
Running good so far.
davepnola
December 2nd, 2010 09:00 PM
vmathy
May 31st, 2010 04:32 PM
oldzy
April 6th, 2010 11:22 AM
Flye
July 31st, 2009 04:03 PM
68conv455
May 20th, 2008 02:03 PM
Quick Reply: Fuel vapor return line
