Header bolt issues
Old May 25, 2016 | 05:01 AM
wr1970's Avatar
Header bolt issues
How many have had trouble with the bolting the drivers side bolt closest to fire wall?
Old May 25, 2016 | 05:15 AM
ELY442's Avatar
What kind of a problem are you having? Cant fit a wrench or a socket in there? What brand of headers are you using?
Old May 25, 2016 | 05:20 AM
wr1970's Avatar
I am not having problems i know that bolt can be tough to get installed on some brand of headers. I came up with two solutions.#1 is a stud #2 which worked the best for me is slot that hole in the header and have the bolt loosely installed and slip the header into it.
Old May 25, 2016 | 05:24 AM
ELY442's Avatar
Good idea but my headers already came with the slot.
Old May 25, 2016 | 06:44 AM
boese1978's Avatar
I use the shortest possible 7/16 open end and manage......
Old May 25, 2016 | 07:27 AM
70cutty's Avatar
Beer Connoisseur
I usually tighten that one from under the car.
Old May 25, 2016 | 07:54 AM
coppercutlass's Avatar
Chevy budget Olds powered
I cut my wheel housing in the front to have access to the header bolts from the wheel openings. So I do it with the car jacked up partially. So much easier.
Old May 25, 2016 | 12:11 PM
I didn't have any issues with the bolts. Heddman Hedders built in the late 1980s.
Old May 25, 2016 | 12:33 PM
I did mine so I wouldn't have to bend over the fenders. Much easier on my back
SD72cutlass
Suspension & Handling
Feb 13, 2018 05:27 PM
NMcCarthy
Nov 16, 2014 08:03 AM
rootney
Aug 21, 2013 04:24 PM
Kidcutty
Mar 29, 2010 03:23 PM
<Brian>
Sep 9, 2004 09:38 AM
