Valve spring choices
Old Aug 21, 2015 | 09:40 PM
young olds's Avatar
comp cams recommends 995-16 springs for my cam but they say machine work needs to be done. Is there anything I can put on without machine work that are a suitable replacement for them. I think I have valve float so I want to get different springs on there but don't want to pull my heads.
Old Aug 22, 2015 | 05:39 AM
wr1970's Avatar
cutlassefi Ask Mark he can answer that question i am sure.
Old Aug 22, 2015 | 08:20 AM
young olds's Avatar
Should have done a search first, which I normally do, I found a thread where the same question was asked about these springs. This thread can be deleted
Old Aug 22, 2015 | 02:55 PM
cutlassefi's Avatar
Flat taopet or roller cam? A little more info would be nice.
You'll probably need to cut the guides, the inner diameter is fairly small. That may be what they mean.
They list them as a roller spring. They're airtime light on the seat for that, and not quite enough over the nose. Not something I would use but need more info.
Old Aug 22, 2015 | 06:59 PM
Run to Rund's Avatar
For me, the first step is to determine what spring will give the desired seat and open pressures, for the possible installed heights with available retainers, locks, and spring cups or hardened shims (such as Comp offers). The Comp recommendation is fine if you can achieve the installed height needed to use that spring. I routinely use Comp, Isky, Crower, etc. catalogs to search for the best spring combination for a given cam. I generally use the Isky 507STA retainer which gives more installed height than the 507ST, and is short underneath to give more clearance to the guide. I like the Howards seals that are not real thick on top, again for retainer to guide clearance. It is best to minimize cutting off the height of the guides.
Old Aug 22, 2015 | 08:59 PM
young olds's Avatar
I'm going to get a spring off and do some measuring
Old Aug 24, 2015 | 08:56 PM
young olds's Avatar
My Installed height with stock retainers is approx. 1.840 and I have a hydraulic flat tappet cam
Old Aug 30, 2015 | 10:29 PM
young olds's Avatar
i tried looking on summit for springs but realized idk what im doing.
Old Aug 31, 2015 | 05:43 AM
cutlassefi's Avatar
I can get you springs if you still need them.
Old Sep 27, 2015 | 12:36 PM
young olds's Avatar
I am still looking for springs if you, or anyone else, can help. Jus let me know the info you need
Old Sep 27, 2015 | 02:47 PM
cutlassefi's Avatar
Springs would be $85.00 shipped.
Old Sep 27, 2015 | 08:51 PM
young olds's Avatar
Perfect! ill pm you about payment
Old Oct 1, 2015 | 08:13 AM
young olds's Avatar
Pm sent
Old Oct 4, 2015 | 12:31 PM
young olds's Avatar
Are you getting my pm's mark? Idk if my pm's are sending as my last three I sent I didn't get any replies
Old Oct 8, 2015 | 09:22 PM
young olds's Avatar
Still waiting to hear from you, understand if your busy though
Old Oct 9, 2015 | 03:49 AM
cutlassefi's Avatar
Don't think I got any of them. Email me at fastone01@hotmail.com
Thanks.
Old Oct 9, 2015 | 08:12 AM
young olds's Avatar
Done
johnnyjaws
Feb 23, 2015 04:30 PM
Aceshigh
Feb 24, 2010 07:15 AM
procharged70cutlass
Dec 21, 2009 08:03 PM
Longhorncutlass
Mar 2, 2009 01:53 PM
ImWired
Dec 19, 2006 05:40 AM
