Auto Trans Neutral Lockout Mod
Old Apr 10, 2014 | 07:26 PM
Sarum's Avatar
Hi from New Zealand
I have a TH350 trans in my 1965 Cutlass Sports Coupe with a T bar on the floor console.I have to press the button on the side of the T bar to select Low which gives me 1st and 2nd stage.This means that top gear is selected by shifting forward without a lockout and also means that you can easily go to far and hit Neutral as happened to me during some friendly drag racing (not ideal) As the lockout facility is operated mechanically is it possible to alter the trans so that a lockout button push is needed to select Neutral? I would be happy to lose the lockout on Low if required but I do want to keep the look of things as they are.Thanks for any response
PS I wasn't sure where I should post this query as it could have also gone into trans/drivelines etc Any comments?
Old Apr 10, 2014 | 07:30 PM
Sure. You'll just have to create a new gear selector sector.
I can't say for certain in your car, but generally it is a quarter-ring of steel attached to the floor shifter with two bolts that engages the other end of that lockout button.
Watch it work, remove it, trace it, use the tracing to figure out the contour that you want, and then cut a new piece.
Old Apr 10, 2014 | 08:19 PM
You can make an electro-mechanical stop or just a plain ol mechanical one. Jus need a bit of creativity.
Old Apr 10, 2014 | 08:21 PM
2blu442's Avatar
Eric, here's some photos of the 1964-66 automatic floor shifter. Of course, this one has the T handle broken off as so many of them do. But what I've called a detent, and I think this may be what your calling the gear selector sector can be clearly seen in these photos. John
P.S. this one looks like someone modified it, like they cut the notches differently than was factory.
Old Apr 10, 2014 | 08:26 PM
Yup, that's the part.
Thanks, John!
Old Apr 10, 2014 | 11:12 PM
Sarum's Avatar
Thanks very much for your quick reply and modification idea. I figured it can't be too difficult and would have thought it was a commonplace modification but maybe not. Almost a safety thing to prevent over revving an already high rpm operating engine.
I had practiced shifting from Low to Drive and it only requires a small movement to start the shift happening as it feels spring loaded.Unfortunately in all the excitement of first time drag racing it proved to be a too subtle thing for my brain and coordination to attempt at the time!
Old Apr 10, 2014 | 11:15 PM
Sarum's Avatar
Thanks for your reply Eric.I think the KISS principle should be observed here and a plain mechanical change would be my preference.
Old Apr 10, 2014 | 11:27 PM
Sarum's Avatar
Very impressed with your reply and the explanatory images.I guess my set up will be a little different but the principle will be the same. The other good thing about the scenario is that I know some good engineers so I may not have to take the car to a transmission specialist now.
Have to ask, did you already have these photos or did you take them especially for my query?
I think it may be worth documenting what I end up doing with the modification as I believe there would be a lot of Old's owners that have cars with a TH350 transmission transplant.
Thanks again.
Last edited by Sarum; Apr 10, 2014 at 11:30 PM. Reason: Didn't need the images displayed again
Old Apr 12, 2014 | 05:23 AM
2blu442's Avatar
Thanks again.
Over the years I've had a lot of project and parts cars. I've taken lots of photos to use as references and when questions like yours come up its just a matter of locating the right photos. One of the things I appreciate about the community here is that between us we can respond to most questions that come up with these cars.
Old Apr 12, 2014 | 03:32 PM
Sarum's Avatar
This site is awesome for someone like me who is new to Oldsmobiles and lives at the bottom of the South Pacific. Cars like my Cutlass are rare down here in New Zealand.As an illustration of this is that I am yet to see ( in the flesh) ANY Cutlass's never mind a '65 Sports Coupe like mine. The closest I have come is when I was parked beside a white (like mine) '65 88 model Old's at a car show a couple of months ago. Pretty cool even so, looked like big brother and little brother.
Cheers
allyolds68
Jan 22, 2014 07:11 PM
dfire25
Jan 24, 2013 10:13 AM
benji94
Oct 10, 2012 08:40 AM
StickW31
Oct 22, 2010 08:47 AM
72' Convertible
May 21, 2009 12:46 PM
