4 Bolt main 455 race block
Old Apr 12, 2016 | 05:31 PM
7903sc's Avatar
What are you using to beef up the bottom end of your race big block. I have been using Dave Smiths caps since 1983 Alum caps are on a 482 that is being up dated and the steel caps are going on a new 482 build. Lets see what you guys are using??
e 1983
Old Apr 13, 2016 | 05:22 AM
Milan..'s Avatar
temp image upload
Jeff Smith girdle , Program steel caps , 790hp and turns 7700 rpm in the lights 4.200 stroke... Thanks Milan
Old Apr 13, 2016 | 10:51 AM
7903sc's Avatar
Very nice Milan, how fast and what are you running it in? I ran a 497 in the 90s turned it to 7600 no block problems just a crank every 2 years 4.375. It ran 8.50s. building a 482 looking to run the same???
Old Apr 13, 2016 | 12:55 PM
Milan..'s Avatar
My car has gone a best of 9.35 @ 142.94 , race weight is 3360 , best 60 was 1.26.. There is a thread on my car in this section....
Old Apr 13, 2016 | 01:30 PM
7903sc's Avatar
Milan, I found it. Very impressive, It's nice to find someone making that kind of power. Wish we lived closer so we could speak Olds. By the end of the year I will have 1 of my 482s in the car. back in the 90s i ran a 497. had to make almost every
thing!!
Old Apr 13, 2016 | 03:59 PM
wr1970's Avatar
With guys like you Alan and Milan on this site it is very helpful to us slower guys trying to go faster.
Old Apr 13, 2016 | 04:54 PM
7903sc's Avatar
I would be more than happy to help in any way I can.
Old Apr 14, 2016 | 06:03 PM
wr1970's Avatar
Alan what are your thoughts on a stock cast crank stroked to make a 482?
Old Apr 14, 2016 | 06:32 PM
7903sc's Avatar
If it's for a street car it would be ok, when you offset grind a crank the rod journal starts out at 2.500 and when its done it's a 2.200 .300 is a lot to take off a cast crank. i would start with a steel crank if it was me. Also if I was building a 482 for the street I would find a early block 68 F,68 F0,68 F00 bore the block .125 use a stock 4.250 crank = 482.33
Old Apr 14, 2016 | 07:20 PM
wr1970's Avatar
It isn't for the street. I have a 455 steel crank.
Old Apr 15, 2016 | 10:05 AM
7903sc's Avatar
I would use that crank up to 700hp, any higher I would go aftermarket!
Old Apr 17, 2016 | 07:45 AM
chadman's Avatar
Here is what's going in my new build.
Old Apr 17, 2016 | 07:49 AM
chadman's Avatar
Old Apr 17, 2016 | 07:52 AM
wr1970's Avatar
Are you not a little worried abut the webs cracking with that. The pan rail looks to be stronger.JMO
Old Apr 17, 2016 | 07:56 AM
chadman's Avatar
No, if you see it in person where the splayed bolts tie in is actually thicker than the pan rail especially after you drill out the pan rail to a larger size bolt hole. Let's face it, none of these Band-Aids are ideal.
Old Apr 17, 2016 | 08:04 AM
cutlassefi's Avatar
X2. But my hat's off to you guys who've been able to make this stuff live at that level.
Old Apr 17, 2016 | 12:37 PM
7903sc's Avatar
chadman, nice piece that crank will take a lot of stress off the block. I would like to see the whole build, good heads and cam you will have a power house!!
Old Apr 17, 2016 | 01:08 PM
wr1970's Avatar
That is a nice crank. What was cost and time frame.Not that i can buy one no job.
Old Apr 18, 2016 | 03:42 AM
chadman's Avatar
The engine will be 494 CID (4.25x4.35) with a Bryant crank, GRP rods, Wiseco pistons (13.5:1), Edelbrock heads originally CNC'd by Knowlton (2.19 Int. 1.65 Ex.) and then hand worked some more, a pretty big solid roller cam, Victor intake and a 1050 Dominator built by Milan.
It won't be a max effort build but more of a purpose built engine. That purpose is to put a 3400 lb. car under 9.90 E.T. in the heat of the summer, be reliable and run on readily available 112 race fuel. I figure I need to make 725-750 HP to do that so that's the goal.
Old Apr 18, 2016 | 03:45 AM
chadman's Avatar
Just a tad under 3k balanced and shipped to my door. Six months lead time.
Old Apr 18, 2016 | 07:54 AM
young olds's Avatar
Chadman, where did you get those caps? And did you fill the block at all?
Old Apr 18, 2016 | 08:45 AM
wr1970's Avatar
Chadman are those are splayed caps?
Old Apr 18, 2016 | 08:57 AM
chadman's Avatar
Caps are from M&J Proformance. My block is filled to the water pump holes.
Old Apr 18, 2016 | 08:59 AM
chadman's Avatar
Yes. The splayed bolts tie into the "skirt" of the block.
Old Apr 18, 2016 | 09:54 AM
7903sc's Avatar
Nice build I think you will hit your HP goal easy, If you want to test in a lightweight car let me know!!!
Old Apr 18, 2016 | 07:04 PM
young olds's Avatar
I've been wanting to buy a set of his, nice to finally see them on something. Do you have to fill? How well do big blocks stay cool filled as high as you did?
Old Apr 19, 2016 | 03:21 AM
chadman's Avatar
Yes the block needs to be filled due to the splayed bolts entering the water passages. For street use I would recommend an external oil cooler with a 1/2 filled block.
Old Apr 19, 2016 | 01:10 PM
young olds's Avatar
Does the fill give the bolts some extra material to thread into or is it just to seal them off?
Old Apr 19, 2016 | 02:01 PM
chadman's Avatar
The filler is for strength. You use sealant on the threads of the screws for the coolant.
Old Apr 19, 2016 | 04:39 PM
young olds's Avatar
ok
Octania
Jan 15, 2015 10:01 AM
RandyS
Aug 18, 2014 08:16 AM
67 Cutlass Freak
Dec 18, 2012 07:05 PM
theoldsrocket
Jul 19, 2011 04:55 PM
Mr.Cutloose
Apr 7, 2010 06:12 AM
