putting a groove on crank
Old July 30th, 2014, 12:05 PM
swat455
steve walker's Avatar
Talking putting a groove on crank
hi has anybody tried adding a groove in center for each rod on the crank so oil goes 360 around the connecting rod bearings . and adding hi vol oil pump... whats the diff between that and some main bearings doing that .as im thinking of trying that on the next olds build ......
steve walker is offline
Old July 30th, 2014, 12:40 PM
morgan
pogo69's Avatar
you sound like Smokey Yunick
pogo69 is offline
Old July 31st, 2014, 03:41 AM
Engine Builder
Smitty275's Avatar
Well, you could. I would bet to say that it has already been done. If by no one else than engine designers from way back when. But it would serve no purpose but to cut your load bearing ability in half. The rods get plenty of oil, if your getting plenty of oil to the crank to begin with. You'd be better served with modifying the first few feet of the oiling system in the block to help the oil get to the main galleys.
Smitty275 is offline
68 D88
January 9th, 2015 03:40 AM
russell-t
September 29th, 2011 08:26 AM
josh77
May 16th, 2011 05:44 AM
sx455raidercelticfan
November 23rd, 2010 05:45 AM
Droptop
July 7th, 2007 06:10 PM
Quick Reply: putting a groove on crank
