OL4B intake question
Old Feb 13, 2015 | 11:20 AM
rickracer's Avatar
Hey guys, I've got a stock 350 with a HEI dizzy and was wondering if an old style OL4B intake would fit with that HEI?
I know an Eddy Performer or Performer RPM will but I'd rather have an OL4B since my internals are stock. I do have an old Offy 360 on her now with a 600 cfm Holley which works fine but that Offy can't be any better than a stock 4bbl iron intake. I want to keep the stock cam so the OL4B seems best.
The more I read about the OL4B the more I think the Performer RPM is the way to go....I can keep adding to the build and have a great intake. Besides that the OL4B is for a spread bore only if I'm correct.
Old Feb 14, 2015 | 03:14 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have seen the OL4B in square bore as well. The RPM intake is good intake that will work OK with a stock motor.
Old Feb 15, 2015 | 07:41 AM
cutlassefi's Avatar
Use the Performer RPM, especially with that 600 carb. And don't worry about mixture "velocity" with that intake. Have you seen how small the runners are?
Thanks.
Old Feb 18, 2015 | 10:20 AM
rickracer's Avatar
I found this pic on the net, no sure how reliable it is but this OL4B is installed on a 403 with an HEI. Not sure if the 350 and 403 use the same block casting or not.
With the cap installed I'm sure it would need some clearance work on the intake to work. I don't like that little of clearance so going with a RPM might be better.
Old Jul 16, 2015 | 09:31 AM
oldsmike1972's Avatar
I had to grind on my intake when I was running it. Going from memory, maybe .050-.075 deep, about 2" long and about 0.500 wide.
StickW31
Dec 28, 2014 03:03 PM
1978 Oldsmobile Omega
Jul 7, 2014 05:14 PM
ihengineer76
May 25, 2013 06:52 PM
OldsMotion
Oct 12, 2012 07:05 PM
Shradezz70S
Jul 28, 2012 10:01 AM
