Racing Calculator Thread
Old August 9th, 2015, 11:31 AM
wr1970's Avatar
This thread is for calculators, here's a link I use often. Please add calculators that you find helpful.
http://www.wallaceracing.com/Calculators.htm
wr1970 is offline
Old February 6th, 2016, 03:36 AM
car nut farmer
71rocket's Avatar
Cool, thanks
71rocket is offline
Old March 15th, 2017, 01:58 PM
74sprint's Avatar
Olds BB combustion chamber measurements
For the life of me I could not find measurements of the Olds BB combustion chambers. Almost all of the BBO combustion chambers are the same size and are 80cc. These drawings are of the actual stock 'G' & 'J' heads but, the distance between the valves is the same for all heads big and small. The distance between valves is 2.0" which is also the distance between rocker bolts/studs and push rods. Pontiacs also have a 2.0" spacing so you can use Pontiac guide plates, even the stock ones, just cut the 2 cylinders apart, the plates do 2 cylinders. The 'J' heads distance varies a lot, from 1.987" to 2.010" all on the same head, wow. The combustion chamber with the larger valves is for my new build. Any questions pm me and I'll try to answer them.
Ray
File Type: rar
74sprint is offline
Old March 5th, 2020, 09:23 AM
Letsrunum's Avatar
Thank you for sharing!
Letsrunum is offline
R_CK_R
February 8th, 2017 10:15 PM
alex.1979
July 5th, 2015 07:10 PM
Marx3
April 12th, 2015 05:02 AM
777rickr
Tech Editor's Desk
June 11th, 2014 07:38 AM
Djcoak
December 17th, 2013 07:49 PM
Quick Reply: Racing Calculator Thread
