wheel hop
Old Feb 29, 2016 | 03:24 PM
jwr7042's Avatar
wheel hop
I have a 70 442 built to drag race and it is all new. Have just finished. No passes. Went to test and had a violent wheel hop problem. As I said this is new I have 3.91 gears 4 speed tranny adjustable upper trailing arm and lower are after market also. I have air bags in both sides and will experiment with pressures. Read 15# on the right and 5# on left. I have 10" street cheater slicks. I heard someone makes a part to stop wheel hop or help. Anyone have any advice or help
Old Feb 29, 2016 | 03:48 PM
BackInTheGame's Avatar
Back in the day I used Lakewood ladder bars. TOTAL hookup.
Old Feb 29, 2016 | 04:48 PM
TripDeuces's Avatar
I'd check the pinion angle at rest. I think coil spring cars need a down angle of 2-3 degrees at rest.
Are the lower arms adjustable for length?
What type shocks are on it?
What type bushings in the control arms?
Your air bags are in the correct range but try this once you get the wheel hop fixed. Do a burnout and if the car wants to drift left add more air in the right bag. I usually start at a lower pressure like 8-10 psi in the right and work my way up until it stops drifting left. It won't take much as I never had to go over 15 psi in that right bag.
Old Feb 29, 2016 | 04:50 PM
Some people like No Hop Bars.
Old Feb 29, 2016 | 05:26 PM
jwr7042's Avatar
The shocks are Monroe 90-10 in front and Monroe gas in rear. the bushings are stock I am going to change those. upper control arms are adj but bottom is not. I will have to play with it a little to get it right. Thank you for your help.
Old Feb 29, 2016 | 05:40 PM
jwr7042's Avatar
What do you mean no hop bars? traction bars
Old Feb 29, 2016 | 05:44 PM
RetroRanger's Avatar
72 Olds CS
http://www.summitracing.com/parts/edl-5213
no hop bars i have never tried them
Old Feb 29, 2016 | 05:58 PM
coppercutlass's Avatar
Chevy budget Olds powered
Here is what I'm running. No wheel hop at all. Home boxed lowers which consist of 1/4 in plate across the whole bottom of the lower control arms. New rubber bushings, 442 rear Springs and one air bag in the right rear. I can spin them up with no issues no wheel hop. I have ran the no hop bars but I found I ended up with a bent axle tube. From the way it loads on the rear end. Relocation brackets for the lowers are the way to go. Essentially the same as the no hop bars but more practical imo. I don't think air bags will help with the wheel hop much imo specially if the rest of the suspension is worn out. You need something to plant the tires if your suspension is up to par. meaning Boxed lowers , new bushings , etc etc.
Old Feb 29, 2016 | 07:30 PM
Yes these:
Old Mar 1, 2016 | 04:15 AM
scottv442's Avatar
Maintained
Estimated Ship Date: 2/28/2018!!
now thats a long back order time
Old Mar 1, 2016 | 04:42 AM
Hmmmm, good things come to those that wait? There are other manufacturers who make a version I believe.
Old Mar 1, 2016 | 05:20 AM
gs72's Avatar
72Cutlass S
We call that Galactic back order.
Old Mar 1, 2016 | 08:39 AM
young olds's Avatar
I'd lower it before I used no hops. You want your upper control arms at least level at ride hieght. If you can get them to point down at the frame, have the upper bar higher at the axle then the frame, that's even better.
Old Mar 1, 2016 | 09:28 AM
wr1970's Avatar
Are both rear wheels hopping or just drivers side? Get someone to watch or video tells the whole story frame by frame.Much better than eyeballs.JMHO
Old Mar 1, 2016 | 11:17 AM
1BOSS83's Avatar
x2- I chased wheel hop around and it ended up being the transmission. Not saying that is the same case here but some visual evidence will help with diagnostics.
Old Mar 16, 2016 | 06:41 AM
rtanner's Avatar
BTW, something I do on every A-body I get, is loosen of the bolts and nuts a hair, at all 8 control arm location points, most of the time ill pull the bolts and coat them w never seize, and the faces of the bushings, a lot of people over look this, and especially on a new build if you gorilla tightened all your mounting point bolts, the potential for suspension bind is high, and bind creates incurable wheel hop, also like was said previously, rear ride height low if possible.
Old Mar 16, 2016 | 06:50 AM
Chesrown 67 OAI's Avatar
x2 on rtanner above. if you installed your control arms and tightened them "gootentite" - then you have a problem with the housing not being able to move freely. If they are tightened -- loosen the bolts until each control arm will move freely by its self, you sould never be able to push an upper control arm up and have it stick there!! it should fall back down. Im guessing thats your problem --
JUST SAY NO TO "NO HOP BARS" on a street car -- they will shake your back teeth loose. You will lose all ride qualities. MOO
Old May 10, 2016 | 09:38 AM
HWYSTR455's Avatar
If the bushings are good in the control arms, 9 times out of 10 it's shocks and/or springs. Those Monroe shocks are junk. That would be the first thing I change out, and bet that will solve your problem.
Wheel hop is from wrap up and unloading, = shocks and springs.
The bags probably make it worse.
Put a set of Bilsteins on the rear, make sure your trans and engine mounts are good, and recheck your control arm bushings. If you still have a problem, go to new or higher rate rear coils.
I've used no hop bars on the street without any ride quality change. All they do is change the instant center point, which loads the wheel harder downward. Corner exit speed suffers, so if you're a road/circuit or autocross guy, probably not for you.
EDIT: Bounce the rear of the car, if it goes up and down more than once, shocks are toast.
Old May 11, 2016 | 09:59 AM
GEARMAN69's Avatar
Ride height as mentioned and levelness of control arms parallel to pavement makes a big difference. My experience in drag racing old stuff like saggy springs actually made my A body cars work fantastic as is. But they were lower than a new stiff set of springs would be. I do run OEM boxed lower arms and sway bar too. if loosening the bolts and letting it settle doesn't help and it is new springs with a taller stance that is going to stay just get the pinion angle correct first after that if still a problem then the "no hop" relocating upper brackets/bars should take care of it if all else fails. Keep in mind spinning on the street and hopping from that doesn't mean it will hop at track if the is sticking it may be fine if it just hooks.
67flamedcutlass
Dec 19, 2019 07:54 AM
Steve g
Drivetrain/Differentials
Aug 29, 2013 08:43 AM
w-31cutlass
Suspension & Handling
16
Sep 12, 2011 08:58 AM
mugzilla
Tech Editor's Desk
Oct 16, 2008 11:26 PM
