Spark Plug Color
Old Aug 16, 2015 | 07:31 PM
fastolds's Avatar
Spark Plug Color
I pulled the plugs out of my olds and wanted some opinions on if the color represents a good tune. They have been in for 10 passes and 100 miles on the street.
Old Aug 16, 2015 | 07:32 PM
fastolds's Avatar
Other side.
Old Aug 17, 2015 | 01:50 AM
442mark's Avatar
Looks good to me.
Old Aug 17, 2015 | 05:52 AM
fastolds's Avatar
I replaced these with NGK and set the gap at .060 as all the reading I have done suggests .045 to .060 depending on ignition.
Old Aug 17, 2015 | 11:09 AM
Ozzie's Avatar
In general they look good. #3 & #6 look a bit darker, but not seriously. After you run the NGKs for a while, you can compare them. so save your photos.
Old Aug 19, 2015 | 08:36 AM
young olds's Avatar
Speaking of plug color, these are from a 30mn trip mostly freeway. Pulled not to long after I got home.
I had a pretty bad lean surge but was less noticeable on the freeway. This is with 67 jets, I went to 69 and it seems to be gone but I feel like I can still hear it in the exhaust
Old Aug 21, 2015 | 09:10 PM
TripDeuces's Avatar
The problem with spark plug color is it has to be done immediately. You can't take an extended trip with a new set of plugs and get a good reading.
Easy way to do it is to put in a new set and take a 1/4 mile blast right away. Ideally you can shut the engine off at the end of the run and coast to a stop. Now remove a plug and look at it.
Honestly your plugs don't look bad and I'm not understanding the lean surge. At least by the way the plugs look
Old Aug 21, 2015 | 09:42 PM
young olds's Avatar
I haven't done to many wot blast yet. A definite surge with 66/67 jets, 69 make it barely noticeable. I'm going to try 70 and see what that does. Can you get a surge from anything else?
Old Aug 22, 2015 | 06:53 AM
TripDeuces's Avatar
Vacuum leak will act like a lean condition
Old Sep 17, 2015 | 03:04 PM
young olds's Avatar
Just found out my vacuum advance doesn't work and is a vacuum leak, swapped it for a good one but have not driven it
bonesbmx
Jun 2, 2020 02:10 PM
ChrisM
Mar 7, 2009 08:07 PM
ChrisM
Nov 1, 2007 02:23 PM
66starfire
Jan 3, 2007 10:31 AM
<james.reinhart@detroitdie>
Jul 24, 2004 09:34 PM
