1972 delta 88 2d street strip car
9's with that tank you better have deep pockets it takes more than just the hp to make it boogie down the track.
Im not going to be a debbie downer but i doubt it does 14's in the 1/4 with a small block.
Monster Garage
I can give you an example ------ We did the blue Cadillac 4 dr.Sedan De Ville over twenty years ago that raced Jesse James on Monster Garage. 496 Olds stroker motor , ATI 400 turbo , 4.10 nine inch Ford rear. Street driven 4600 lbs. 10.80s @ 122 . ------
Putting one of these boats into the 14s is very good. Gearing is your friend. 4.10's. You need a healthy fresh 455 with good flowing heads. Cutlass headers will fit but on the drivers side the tubes need to be heated and bent down a tad. I would use an engine plate at least on the front to keep the block from flexing. If you want to get real serious you will need a rear engine plate also. Heavy car to get moving, build for torque. Plan out your "battle plan". I'm not sure of the amount of torque the stock drive shaft and/or the axles will handle. My turquoise 98's best was 14.13 @ 100 mph. It weighs 4680# without me. The pre 1971 B/C body cars are rear steering that may headers non existing. Gearing is limited, I have a 3.08 posi. The engine has gone 11.50s with a different camshaft in a G-body. The launches are hard on the block and it had a main bearing problem and I don't put slicks on it anymore. One thing for sure is you'll be the only 1972 Delta at the dragstrip. Good luck.
anthonylenhardt
March 29th, 2007 07:54 AM
anthonylenhardt
March 28th, 2007 11:30 PM
<johnny5>
Cars Wanted
August 25th, 2005 12:46 PM
