Not so impressive track run
Old Jul 16, 2016 | 10:04 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
First run was decent, good launch but accidently short shifted and still smoked the guy in the next lane. First two cars out and of course the time ticket machine had issues. Next launch was brutal over foot braked the car and spin out with a brutal 2.9 60 ft and an awful 10.4 in the 1/8. Got pulled over to the side because of a trans leak, thinking it was the over flow hose, I need to add a catch can on there. This the last trip to the track with the 88 CSC, disappointing like every thing else lately.
Old Jul 17, 2016 | 05:30 AM
wr1970's Avatar
I don't really understand. I have had only two failures in over a thousand passes. One was for a broken throttle cable at the 1000 ft mark.The other was when a trans brake didn't hold at the line. Both cost me races for the cash. I did have a fan blade come apart once on the turn pike at 65mph but that don't count because it wasn't at the track. Sorry to hear about your disappointing time at the track. A day at the track is better than a day at home mowing the lawn,cleaning the garage,planting trees,ect,ect.LOL
Old Jul 17, 2016 | 11:00 AM
Just have had nothing go may, ever since the Olds powered 4x4 burned a curse has decended on me.
Old Jul 17, 2016 | 01:14 PM
wr1970's Avatar
Smile good things are around the corner look at it this way you got to go to the track!
Old Jul 17, 2016 | 03:50 PM
True enough, I was only looking for a couple of tenths anyways. I need more can, that will rectified before the 350 goes in the 70 S.
Old Jul 17, 2016 | 05:35 PM
marxjunk's Avatar
theres no curses...its what you decide to do with what your dealt that guides your destiny..in other words..you have control...
you may have set back..but get up..knock the dirt off and keep going forward...
and dont do it the same way next time..learn and change
i think of this often..amd i am guilty many times...
Albert Einstein is widely credited with saying “The definition of insanity is doing the same thing over and over again, but expecting different results”.
Old Jul 17, 2016 | 05:49 PM
https://m.facebook.com/christian.rae...83?pnref=story
Here is the first run, me thinks my opponent did know which way to go.
Old Jul 17, 2016 | 05:52 PM
coppercutlass's Avatar
Chevy budget Olds powered
It happens. It took me almost 3 years to get my car on the track after i bought my house. Engine pooped out . The trans pooped out then my frame finally gave up then my engine popped a head gasket but once it all came together it was worth the fight and effort. The last 2 seasons have been enjoyable and the car has been very enjoyable and trouble free for the most part but it took sometime to get the I's dotted and T's crossed.
Old Jul 17, 2016 | 05:53 PM
Link is not working BTW
Old Jul 17, 2016 | 06:42 PM
Try it now.
Old Jul 17, 2016 | 06:50 PM
facebook video links have never worked for me. still not working
Old Jul 18, 2016 | 05:53 AM
Here is a You Tube link.
Old Jul 18, 2016 | 06:21 PM
wr1970's Avatar
https://youtu.be/2PuBddDD7Dc
LOL My ribs are hurting. Thanks for the link. You are right. The other guy hit his head on the steering wheel while trying to figure out which gear he was in.
Old Jul 19, 2016 | 07:07 AM
It was a great start, then I blew the next race and had to go home with the leak. I was hoping for a personal best again with the 88 before it is retired from the 1/8 mile. Either way the 70 S will be much faster with a cam swap and 3.90 posi vs 3.42 open gears in the G body.
Old Jul 19, 2016 | 10:56 AM
Redog's Avatar
That guy, LOL that's probably the funniest thing I've seen at the track, and I've seen a lot of ricers too.
Old Jul 19, 2016 | 12:09 PM
RocketV8's Avatar
At my track you're not allowed to re-stage like that if you go too deep, you have to back up like 10 feet and stage all over again (to eliminate the risk of starting in reverse). Not a bad idea apparently...
And what's up with the u-turns right after the finish?
Old Jul 19, 2016 | 05:16 PM
Usually it is setup for the otherside during test n tune with no barrier. I think it worked better and went like hell this time because I caught hell last time for going too slow into return lane.
shamusj
Mar 4, 2016 06:48 AM
s i 442
Aug 2, 2013 10:03 PM
69442C
Oct 30, 2012 08:05 AM
Longhorncutlass
May 19, 2011 06:28 AM
RAMBOW
May 27, 2009 05:02 PM
