350 Rocket
Old Aug 17, 2014 | 10:46 PM
bj_72cutlass's Avatar
350 Rocket
Is it possible to make 400HP with a 350 rocket a 72
Old Aug 18, 2014 | 04:01 AM
Smitty275's Avatar
Engine Builder
Absolutely!
Old Aug 18, 2014 | 05:55 AM
Originally Posted by Smitty275
Absolutely!
I wanted to be sure because a lot of people are saying just go with a 455 but I want to stay in the small block class.
Old Aug 18, 2014 | 08:54 AM
455man's Avatar
Depends on how much money you want to spend. Sometimes it's cheaper to just drop in a 455.
Old Aug 18, 2014 | 08:58 AM
$3000 to drop in motor
Old Aug 18, 2014 | 11:40 AM
captjim's Avatar
We have had this discussion 100 times. Why do you want 400 HP? What are you going to do with the car? Street strip, weekend cruiser, etc? As always, goal and budget.
Old Aug 18, 2014 | 11:45 AM
jag1886's Avatar
I don't think that is going to be enough.
Weekend cruiser but occasionally race
Old Aug 18, 2014 | 11:51 AM
How much do you think?
Old Aug 18, 2014 | 02:19 PM
captjim's Avatar
Then you won't need to sacrifice driveability for "400 HP", IMHO.
Old Aug 18, 2014 | 05:37 PM
cutlassefi's Avatar
Twice that if you do it right.
Old Aug 18, 2014 | 05:53 PM
Mr Nick's Avatar
What do you mean small block class? Is that a class of racing at your local track?
Old Aug 18, 2014 | 06:04 PM
Yes I'm in Chicago and they have a feud going on small block n big block.
Old Aug 18, 2014 | 06:32 PM
coppercutlass's Avatar
Chevy budget Olds powered
6k is about right for someone to build it. if you built it you can save some coin but if you don't have the knowledge or tools you will have a bit of a headache. I built my own and after the issues I had after I ran it for one whole season im over 4k and there was a few things I could have done but decided not to . They weren't crucial but they wouldn't hurt either. I spent 1700 on the complete top end that's everything heads intake big valves all new parts but no port work , The bottom end cost me 2k then add 500 for the new cam and timing set I installed along with new cam bearings and installation after I found out the cam had run out and wiped my bearings out the season after i ran it . By the time you add the cost of decking the block , new fasteners aling hone and assembly which where the only things I did not do on my build you would be about 6k . Even if you didn't have my issues. Then you have to add all the nickel and dime stuff like a carb , dist , headers , fuel lines , etc etc etc. I have managed to keep my budgets in check but it has not been with out headache. i don't regret it but its a lot of work and time waiting for the right parts to come along to snag a deal.
Old Aug 18, 2014 | 06:41 PM
67 Cutlass Freak's Avatar
Well it cost me a little over $6500 to put together a SB Olds that's putting out close to 450 HP. Go here to post #737 if you want to see the details-
https://classicoldsmobile.com/forums...niques-19.html
I had the block heads and crank, that's why there's no price for those cores. To build a 400 HP SB Olds can be done with good component selection and quality machine work. I would not trust your build to just any machinist. Seek out an Olds specialist. I would not consider my build @ 11.4:1 compression streetable. There has to be compromises. You need to double your budget or forget about it. If I were to build a strong SB street/ strip engine, I would find a 330 crank, stroke it, use aftermarket rods, custom pistons and probably some Pro Comp heads. If it were primarily street driven, I might lean toward fuel injected. Good luck with your build. You should head out to Byron race track Sept 7 and meet some fellow Olds enthusiasts.
Old Aug 18, 2014 | 06:48 PM
Thanks man that was really helpful
Old Aug 18, 2014 | 08:18 PM
Mr Nick's Avatar
They who?
My SBO makes 420-ish HP and not counting the fuel injection would cost a good $5-6k to do again. I build mine in stages, and some of my parts where used (aluminum heads for example).
If you're on a budget, wait till the budget gets bigger for a small block, dump a mild 455 in there, or buy a used/known combo.
69OLDSCUTCONV
Feb 1, 2011 06:09 AM
cutlassKing
Nov 29, 2010 03:05 PM
gscott819
Jul 28, 2009 07:02 PM
esisson
May 22, 2008 07:47 PM
<Eddie>
Nov 1, 2005 07:30 PM
