Bracket Issues after Aluminum Head Swap, Olds 455 Please Help!
Any advise would be greatly appreciated, I rebuilt my Olds 455 and decided to go with the Edelbrock Heads, my Altenator Bracket now does not fit, the Air Conditioning Compressor is having the same issue. I haven't got to the power steering yet but because it's mounted on the lower section of the block I think it may be in the clear. And advice or past experiences would be greatly appreciated,
Thank you
Your fellow BOP friend...
Thank you
I just did this on my 455 with pro comp heads. 70 442. I am assuming you have an elderbrock intake as well. The front alternator bracket that bolts to the head directly has a lip on the upper and lower side of the bracket on the back side. Grind that lip flush with the bracket going back about an inch on the lower one, and the alternator brackets should bolt up fine from there.
Assuming an aftermarket intake the hole in the a/c bracket that bolts to the intake will need to be oblonged to accommodate where the intake bolt hole is. If it is an elderbrock intake it will require a smaller bolt.
1965F85_scholten
July 13th, 2013 02:57 PM
kandelino
December 20th, 2010 12:54 PM
