Oil restrictors?
Old March 20th, 2018, 06:15 PM
Frankie88's Avatar
Oil restrictors?
So i have problems with my new engine wearing out bearings quite fast . First let me tell you about my old 455 that is rock solid.
It’s a later block , Fa, with a later crankshaft small cn, I don’t know what the clearance is on the rod or mains, but whatever they are it works. It has a hv oil pump, I don’t know what spring, but it is not shimmed, and has a 5 qt pan. The block has cam bearing restrictors with regular cam bearings, the cam is a JM 25 28 hydualic flat tappet. It has Joe Mondello restricted pushrods, Scorpion rockers. The heads are iron E heads with Ferra valves and no drainback mods. Torker intake with Holley 950. I’Ve had this engine about four years and spanked it regularly, runs flawless. I shift it at 6500 ish all the time, thats right around where it stops pulling. Oil pressure is always 60 psi at high rpm. Also Clevite full groove mains.
The new 455 is built more for racing. Older F block with no cam bearing restrictors. Crank is a bigN one. That one is ground for large clearances, 4 thou. It has had Speed pro half grooved bearings and Clevite full groove bearings. Also a high volume oil pump with shimmed green spring, and a eight qt pan with correct 2” drop pickup. I have Eagle rod’s with Icon flat top pistons. The cam is a Cam Motion solid roller with 609/254-586/258 on 108 LSA. Crower 66294h lifters and no lifter bore restrictors. 3/8 unrestricted pushrods. To top it off i have a Edelbrock heads with 57cc chambers, so it comes out to 12/5:1. Also a Torker and same 950. Also Jesel shaft rockers.
This engine gets about 15 minutes out of a set of rod bearings. I have never even really opened it up yet. The first time i had it together i was at a stoplight idleing in gear and watched the oil pressure drop off slowly and would not move when the engine was revved. Got it apart and it had shredded the rod bearings,mains not too bad. So I thought it was too tight, 3 on mains,2.5 on rods. Got the crank ground for 4 thou everywhere. Ran it for about 15 minutes at low rpm around 3000, got home cut the filter with snips, lots of copper and silver. It had great oil pressure and no mechanical noise. Got it apart and it was the rod bearings again. The machinist checked the rods before and so did i, they were good,the crank measures right on everywhere.
So i guess i almost have a magazine test article going on here. To restrict or not to restrict, that is the question.
Frankie88 is offline
Old March 21st, 2018, 02:34 PM
cutlassefi's Avatar
Restrictors has nothing to do with it. Was that assembly balanced? Internal, External?
Side clearance on the rods?
cutlassefi is offline
Old March 21st, 2018, 03:25 PM
Frankie88's Avatar
It is externally balanced. .014 side clearance. BHJ external balance dampner and a ATI external balance flexplate.
Old March 22nd, 2018, 02:36 PM
cutlassefi's Avatar
But this rotating assembly was balanced?
Old March 22nd, 2018, 04:42 PM
Frankie88's Avatar
Yes,the assembly was balanced.
Old March 22nd, 2018, 05:58 PM
cutlassefi's Avatar
It wipes out all of them or just a few?
Old March 22nd, 2018, 06:35 PM
Frankie88's Avatar
The bearings on the front rod journal look the best,not even into the tin. Six and seven are the worst.
Old March 23rd, 2018, 04:58 AM
cutlassefi's Avatar
If the oil holes are clear then you have a balance problem. How does #4 main look?
Old March 23rd, 2018, 08:46 AM
TripDeuces's Avatar
Let's see the bearings
TripDeuces is offline
Old March 23rd, 2018, 03:35 PM
Frankie88's Avatar
Old March 23rd, 2018, 03:38 PM
Frankie88's Avatar
Rods seven and eight are at the machine shop,wanted to get them checked out
Old March 23rd, 2018, 04:47 PM
Any chance the rod is bent? Seems the wear is concentrated on one side of the bearing.
matt69olds is offline
Old March 23rd, 2018, 05:02 PM
RandyS's Avatar
Or maybe rod not centered on wrist pin?
RandyS is offline
Old March 23rd, 2018, 05:12 PM
TripDeuces's Avatar
Does the crankshaft have a fillet and the bearings are facing the correct way? They have an offset built in just for that reason.
Clearly they are worn on one side more than the other. Is there taper on the rod journal from one side to the other? Lastly, what was the breakaway torque to get that short block assembly rotating?
Old March 23rd, 2018, 05:32 PM
cutlassefi's Avatar
You need to find another machinist, he sucks.
Just because things are in size doesn’t mean They’re IN-LINE.
I see clear misalignment issues and most likely a poor relationship between the angle of the rods/pistons vs the cylinders, they’re most likely not perpendicular. I believe your crank pins aren’t parallel either.
You need to find a better machinist.
Old March 24th, 2018, 08:40 AM
Frankie88's Avatar
Is there a way I could check to see if the bore’s are square to the crankshaft centerline?
Old March 24th, 2018, 10:34 AM
Inline's Avatar
Well, im not sure what are you asking ( might be me), but you could install rotating assembly with pistons on #1,2,7 & 8 cylinders. Then you can measure bank-to-bank difference between on zero-deck between those two farthest pistons for each other per bank.
Inline is offline
Old March 24th, 2018, 12:40 PM
cutlassefi's Avatar
Huh? That won’t prove what he’s looking for.
The only real way is to mount the block in a boring bar, then run a dual indicator down the bores.
I’d start from scratch and have it align hone first, then measure the square from there.
Old March 24th, 2018, 03:27 PM
Inline's Avatar
Okay, so i wasnt understanding what he was asking for, sorry for that.
Inline is offline
Old March 24th, 2018, 05:42 PM
Frankie88's Avatar
The block was line honed as part of the initial build. I found a different machine shop in town that has a cnc machine that registers on the main line and is able to probe the bore’s to see if everything is in order. Definitely going to have it checked out before going any further
Old March 26th, 2018, 09:35 AM
BillK's Avatar
I cannot imagine how a balance problem would affect rod bearings ? Mains yes but even then not after only 15 minutes of running.
Looks like an oiling problem to me.
BillK is offline
Old March 26th, 2018, 10:12 AM
TripDeuces's Avatar
It looks like a definite taper on those bearings. My guesses:
1) Line hone not square to the cylinder bores (perpendicular) Depending on how this was set up and measured this could cause a bunch of problems. Bad or incorrect math, user error, boring machine tolerances excessive or bent. The piston wants to go straight up and down in the bore but the crank center line angle is not 90* to the bore or the bores aren't square to the crank or deck. Are there excessive wear marks on the piston skirts 90* to the thrust faces? Are the wrist pin bores and or the small end of the rod square. Were the rods reconditioned improperly and not square? This all makes my head spin.
2) Taper on the rod journal. I think this is less likely because measuring the bearing clearance would show a diff between the two rods on the same journal right off the bat. Of course that assumes if it was checked at all.
3) Oil contamination. Why it would be predominately on one side only doesn't fit
#1 is where I'm going
Old March 26th, 2018, 12:18 PM
BillK's Avatar
How about a picture of some of the block main saddles ? And the sides of a couple of pistons ?
BillK is offline
Old March 26th, 2018, 02:15 PM
cutlassefi's Avatar
Op - just because it was align honed doesn't mean it was done correctly. By the looks of the bearings it wasn't.
If the crank is "light" vs the correct bobweight it will beat the pins and rod journals. Early big block Mopars had this problem, they would beat the crap out of the wrist pins.
And once it starts to go the rest of whatever is downstream will too, and it doesn't take long.
Old March 26th, 2018, 06:21 PM
Frankie88's Avatar
Old March 27th, 2018, 06:18 AM
BillK's Avatar
The pistons look fine as near as I can tell from the picture. Can you show one from the "side" of the piston where the most wear would be ? Are the wear marks straight up and down ?
Also a picture or two of the block where the main bearings sit.
Personally I think there might be a combination of issues. Oiling system ? Bearing clearances and how was the crankshaft ground.
Someone else mentioned this . . are the rods on the pistons the correct direction ? I am pretty sure that the bearing "tangs" should be facing in towards the camshaft.
Very hard to troubleshoot something like this without being there in person.
BillK is offline
Old March 27th, 2018, 05:15 PM
Frankie88's Avatar
Yeah definitely hard to diagnose via the Internet. The pistons all look good, no wierd wear or anything like that. All the rods were installed with the chamfer facing the journal cheek. The crank is fine. If the block had cocked bore’s the wear pattern on the bearings would be opposite of each other not concentrated on one side like i have. The thrust is really sealing the deal for lack of lube. I run the same turbo400 and cooler setup with the other engine and never had a problem. This crank’s thrust surface is fine, no sunburst pattern, and very smooth. The only thing that could be causing it to wear as quickly as it does,is lack of oil. It’s going back together pretty soon, ill let you guys know how it turns out. Thank you all for your feedback.
Old March 27th, 2018, 07:17 PM
Bernhard's Avatar
You should find the cause before you put it back together.
Give one of the Olds specific engine builds a call that have build a lot of these engines.
Rocket Racing
BTR Performance
See if they will be willing to help you out ??
Bernhard is offline
Old March 28th, 2018, 06:31 AM
Bernhard's Avatar
What was the oil pressure like ?
4.39 of the video Bill explains main stud interference with the oil pump, that prevents proper seating to the rear main cap.
Bernhard is offline
Old March 29th, 2018, 04:12 PM
Frankie88's Avatar
The oil pressure was good even with the big clearances, 70 cold 45 hot at about 2500 rpm and 25 idleing. I have the max perf olds book, read it cover to cover. It has alot of good info, thats why i had the crank ground for loose clearances the second time around. I’m aware of the oil pump interference with the main cap hardware. My pump is clearenced for it and sits flat on the cap. I have the block tapped for restrictors on the cam bearings and lifter bores . Been doing alot of reading about engines originally designed for hydraulic lifters and trunnion or skid ball rockers, and when the oems put solid lifters in those engines back in the muscle car days. They made the lifters very restrictive, because the block itself flows way more oil than needed. I don’t have one stock component in my valve train, so why leave it stock especially if im wasting bearings at half hour intervals. The crank is getting polished, it’ll be ready tomorrow,just have to clean the block. I’ll let you know how it goes. Thank’s again
Old April 1st, 2018, 01:40 PM
  #31
TripDeuces's Avatar
Found this from Clevite which has a wealth of info.
http://www.wilmink.nl/Clevite/Clevit..._tech_info.pdf
Old April 15th, 2018, 04:13 PM
  #32
Frankie88's Avatar
Old April 15th, 2018, 04:22 PM
  #33
Frankie88's Avatar
Well looks like restrictors worked for me, just got it back together last night. Thats the filter on the second oil change. Drove it around a bunch today, oil pressure is 60 cruising, 30 idleing in gear. Runs perfect no valvetrain noise. Wish i would have done it to begin with.
Old April 15th, 2018, 04:30 PM
  #34
Frankie88's Avatar
Old April 15th, 2018, 04:54 PM
  #35
TripDeuces's Avatar
Great to hear
Old April 15th, 2018, 05:15 PM
  #36
Bernhard's Avatar
That's great news!!!
Bernhard is offline
Old April 15th, 2018, 05:26 PM
  #37
Bernhard's Avatar
Their is a very good Olds engine builder by the name of Milan who used to be a great source of information on ROP.
He did many oil modifications to his builds and his builds were very successful.
I can't remember if he used restrictors?
Bernhard is offline
Old April 15th, 2018, 06:28 PM
  #38
lemoldsnut's Avatar
I have a 60 over 455 that was reported to be done by Joe M. back in the day. Not sure if that is true or not. It was in a full size blazer when i bought it. It has restrictors. Ran great but the previous owner said it like to eat cam bearings. I also have replaced the cam twice in it. I pulled it and it has been sitting. I will fully disassemble it and have it line honed, and balanced. all rods sized checked and corrected if needed and I have a new crank for it. I am replacing the cam and lifters and the heads are going to be fully inspected and what ever needed done. I will not run restrictors in this engine. My main reason is I will not be running it at extreme RPM's it will be a street driving engine. It will be anally cleaned and the oil will be changed often and with great filters and oil. I just don't see a reason to run restrictors on a street engine.
Just my 2 cents
Larry
lemoldsnut is offline
dman0712
May 26th, 2010 05:00 PM
86pontiac
February 17th, 2010 11:24 AM
442 Guatemala
March 28th, 2009 01:58 PM
geckonz08
September 4th, 2008 04:10 PM
neoinbiz
November 6th, 2006 12:11 PM
Quick Reply: Oil restrictors?
