Best place to mount a 6AL box?
Mine "failed" while in an under hood location. There was no moisture problem, but likely could have been a heat problem, as most semi-conductors are heat sensitive. I'd recommend wherever it stays the coolest, especially if it operates in a hot climate. If the car has A/C I'd tend to recommend the passenger compartment. Under the hood gets more air flow, but in the passenger compartment gets lower temperatures in a hot climate. Which results in a lower operating temperature of the unit, I don't know. Perhaps call the technical people at the manufacturer.
Out of Line, Everytime😉
No A/C but our Summer's haven't been very hot but that will change at some point. I think inside is the safest bet under the dash, I leave the fresh air vents open all Summer.
Im going to an msd here real soon. Im mounting it right on the underside of the dash facing the trans tunnel or trans tunnel with small mounting brackets . Looks are secondary to function as well as accessibility . Wont look horrible but then again i dont really have an interior. I dont think trim panels , carpet , and racing buckets count as one lol.
Thanks, this was a great suggestion. I need to lengthen, solder and heat shrink all the connections anyways, so yes to under the dash on the driver's side ground and the motor itself as well. I am also adding an inline fuse on the main power wire as well.
MSD does not recommend installing the ignition box inside any enclosure such as the glove box because of heat build up. I mounted mine on the lower dash below the glove box. Easy access to change rev limiter settings, or for adding any other electronics. You should also be sure to use the rubber vibration dampening mounts. Follow the instructions and run the large hot and ground wires directly to the battery. Do not ground to frame, or body.
On my 66, I made a shallow glove box out of sheet metal, with a plexiglass back (so I could show the MSD 7AL3 box if desired). I mounted the MSD on an aluminum plate and then to the steel cross brace at the bottom of the dash. I can remove two nuts and drop the MSD down to the floor if I need to do something to it. Since the dash did not have a radio, I added the radio brace to help support the weight. I am using the rubber dampers between the MSD and the aluminum plate, and the box is not inside the glove box, but in the open space behind it. Plenty of room and there is no heater in the way.
f-85
August 9th, 2013 09:22 AM
